tire feathering after new wheels
Old May 28, 2011 | 11:51 AM
Blazemaster's Avatar
Blazemaster
Default tire feathering after new wheels
I recently picked up a set of Varrstoen TE reps as 19x10.5 +12 in the rear with a 15mm spacer on Falken 452s 275/35 mounted in the rear. I've been seeing the outer edge of the tire feather, when I go over some dips on the roads at normal highway speeds(70-80mph). I'm pretty sure it's caused by my rear fender making contact with the outer lip of the tire causing it to feather or shred. What should I do? Should I remove the spacer and bring the part that's rubbing in closer to the car? Roll the fender? I want to go with 285 or 295 on the rear tires eventually, but really rather not roll the fender because it's not reversible. Any suggestions?
Old May 28, 2011 | 12:29 PM
skakemokid's Avatar
skakemokid
If rolling is done properly, you dont have to worry about going back.
Old May 28, 2011 | 12:34 PM
No photos. No comment.
Old May 28, 2011 | 05:45 PM
terrasmak's Avatar
A 10.5 inch wide wheel sitting at -3 and a 275 mounted on it. Its not feathering, its rubbing. Take the spacer off, and roll the fender.
Old May 28, 2011 | 06:09 PM
jduet's Avatar
jduet
+100
Old Jun 8, 2011 | 05:59 PM
10 days and no photos. This is the new my350Z.com norm.
