Noob here! Need help with new wheel set up!
2004 350Z stock suspension. Just want to get an expert opinion on whether I will need my fenders rolled with this set up and if I would need some wheel spacers. Thanks!
F 19x8.5 +15 offset 245/35/19
R 19x10 +20 offset 275/35/19
What are you looking to achieve? A flush look... Hellaflush retarded... how long do you plan on having a stock suspension? Search is your friend... You don't need to roll with those offsets if you don't drop the car.
Welcome. Use a offset calculator to compare your current wheels to the new wheels. With the new dimensions, check the car with a tape. Do you clear the suspension, brakes calipers and fenders? Reference: http://www.1010tires.com/WheelOffsetCalculator.asp
Thanks for answering. Just looking for a flush look. I did plan on dropping it but I think I'll wait till I see if I like it or not after putting them on.
No fender roll needed with those size/offset on stock suspension. If you want flush look, put the wheels on, then measure the gap between the fender and the wheels to determine the spacers you'll need.
