fender rolling...
Old May 31, 2011 | 07:25 PM
Chefscott360's Avatar
Chefscott360
Default fender rolling...
So, ive seen tons of he said she said stuff about max RIM and TIRE size for a 350z...so heres my question...will these rims even fit my stock 350z (no lowering or suspention upgrades) assuming i have to do some fender rolling ?!?! thanks
https://my350z.com/forum/wheels-tire...dallas-tx.html
19x9 +24 with 255/40R19
19x11 +24 with 305/30R19
Old May 31, 2011 | 07:29 PM
marques1's Avatar
marques1
Yes, they will fit with no problem. You might want to change the tire setup, though.
Old May 31, 2011 | 08:40 PM
sportbiketed's Avatar
sportbiketed
Use this to calculate the correct tire size:
http://www.1010tires.com/TireSizeCal...?action=submit
Old May 31, 2011 | 09:16 PM
m3a5g0's Avatar
m3a5g0
if you're on stock suspension, you should be fine with this set up. I would do a fender roll anyway if you plan on dropping in the future. You'll have an ugly gap imho so drop it asap
Old Jun 1, 2011 | 03:20 AM
DavesZ#3's Avatar
DavesZ#3
I'm going to have to disagree with all the previous posters. You will have to roll the rears.
I'm running 10½" +22 with 285/35 on he rear and had to roll them because of scraping. You're talking about a wheel that is ½" wider, minimal difference in offset and tires that are 20mm wider. Split the difference on the inside and outside and you're looking at a setup that sticks out another 0.6" more than mine - it will definitely rub. Probably even on minor bumps and dips in the road.
Old Jun 1, 2011 | 05:16 AM
Chefscott360
so theres basically no way to make this set-up work, look right and have the tires tucked under the wells like they should be ? ( sorry im kinda new to the whole tire and rim thing, engines are my spec.)
Old Jun 1, 2011 | 05:23 AM
ZS14RR's Avatar
ZS14RR
i was gonna just say roll fenders. you should be fine. Since you are rolling you might as well do a slight pull.
Old Jun 1, 2011 | 09:01 AM
Chefscott360
so with a fender pull and roll, these should fit under the wheel wells fine, not stick out and not rub ???
Old Jun 1, 2011 | 02:46 PM
terrasmak's Avatar
They will work, but you will need a roll in the rear. Also the proper front tire size is 255/35-19 or if you want the car to handle properly a 275/30-19 will also fit up front.
Old Jun 1, 2011 | 04:43 PM
SLIdEwAyZ25's Avatar
SLIdEwAyZ25
absolutly any tire will fit under the stock suspension setup unless they are like 24's
Old Jun 1, 2011 | 07:01 PM
ZS14RR's Avatar
ZS14RR
they will sit fairly flush but without a drop you will be monstertrucking around town.
Old Jun 3, 2011 | 07:34 AM
Armitage's Avatar
Armitage
I'm going to be running a similar setup in the rear to yours (19x11, +25 offset, 285/35 tire). I plan on rolling the rears (probably fronts too just for *****). How much are you dropped all around?
etkms
Jun 19, 2022 06:30 PM
Justin100
Nov 25, 2021 06:26 AM
Mikey3288
Mid-Atlantic Marketplace
Oct 23, 2015 07:41 AM
Dymsi
Sep 29, 2015 11:32 AM
