Did you guys need extended lugs with +12 offset wheels?
Old Jun 11, 2011 | 11:37 AM
Blazemaster's Avatar
Blazemaster
Default Did you guys need extended stud with +12 offset wheels?
I was using stock wheels with a 15mm spacer that came with extended studs for a while, I finally got new aftermarket wheels that came in +12 offsets. I noticed that a couple of the extended studs in the front are really loose and wiggly, my mechanic suggested I get a new wheel bearing and replace all the studs too. I just picked up the new bearing(ouch...$200), but was wondering if the OEM studs will work just fine. Did you guys with the +12 or similar offset find that you needed extended studs with higher offset wheels?
Old Jun 11, 2011 | 11:45 AM
Max-G's Avatar
Max-G
no. oem is fine.
+12 is a lower offset than the oem fyi
Old Jun 11, 2011 | 12:07 PM
Blazemaster
I'm sorry, I meant if I needed extended studs, not lugs. Did you guys need extended studs?
Old Jun 11, 2011 | 12:28 PM
terrasmak's Avatar
Not needed, but they are nice. Extended studs with extended lugs, its a very strong setup.
ablaine
Nov 29, 2016 10:13 AM
HoBrahYouStink
Jun 24, 2016 10:58 PM
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
Depravity
Oct 1, 2015 04:49 PM
samansharif
Sep 25, 2015 12:31 PM
