Will same tire perform diff. on diff. rim width?
Old Dec 8, 2003 | 02:24 PM
Brad4rdHay's Avatar
Brad4rdHay
Question Will same tire perform diff. on diff. rim width?
Hey, would a 275 tire perform any differntly on a 9.5" wheel versus a 10" wheel?
Old Dec 8, 2003 | 03:12 PM
ares's Avatar
ares
Veteran
it should stretch the tread slightly having you roll slightly more on the edge area but with .5" difference I doubt itd be noticable.
Old Dec 8, 2003 | 03:32 PM
Brad4rdHay's Avatar
Brad4rdHay
what do you mean by roll...not body roll.
Would this cause the tire to break away more easily?
Old Dec 8, 2003 | 03:42 PM
teh215's Avatar
teh215
I believe what he is trying to say is that as the rim gets more narrow, the tread is more likely to have less contact at the edges. I seem to be having a problem with negative camber on my 275/40s in the rear that is causing most of the tread wear to happen on the inner part of the tread. I had is in at the dealership just before I installed the new wheels and tires and it looks like I will have to go back.
Old Dec 9, 2003 | 01:57 AM
jreiter's Avatar
jreiter
Agreed. But, it also depends on what rims widths the tire was designed for. A 275 wide tire from company A could be optimally designed for a 9.5" wide rim, while the same width tire from company B could be optimally designed for a 9" or 10" wide rim.
As a general rule, I look at the tire manufacturer's recommended rim widths and *always* stay within those specs. Ideally, you'd probably follow the "measuring" rim width, as I'd assume that to be the most ideal. (That being the width they used during measuring to obtain all the numbers and stats on their info sheets.)
From most of the tire manufacturers I've seen so far, for 245/40/18 tires they use a measuring rim width of 8.5", and for 275/40/18 tires they use a measuring rim width of 9.5".
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
