RO_JA R2-7 19X10 et 0 Square set up?
Old Jul 16, 2011 | 10:28 AM
350Zsmokinyou's Avatar
350Zsmokinyou
Default RO_JA R2-7 19X10 et 0 Square set up?
Wheels RO_JA R2-7 19X10 ET 0
Set up
Front Tire Stretched 245/35/19.
Rear Tire Moderate 275/30/19.
Suspension Eibach Sportlines with rear camber kit.
Rolling my rear fenders is a givin. Really just wondering if i am going to run into
any unforeseen Problems with this set up. Any insight would be greatly appreciated Thank you!
Attached Thumbnails RO_JA R2-7 19X10 et 0 Square set up?-r2_7_carbon_black.jpg
Old Jul 16, 2011 | 11:06 AM
datsunHEAD's Avatar
datsunHEAD
search mai ninja!!!google,streched tire thread,rimtuck.com
Old Jul 16, 2011 | 11:55 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
I don't understand the point of that wheel. It has a Ro_Ja center cap but still retains the Gram Light "g." So put a Gram Light sticker on the spokes and replace the center cap with Rays...does that make it a 57S Pro?
Old Jul 16, 2011 | 12:53 PM
350Zsmokinyou
Yes the wheels do actually come with gram light spoke stickers. but imo they look kind of cheesy
Old Jul 16, 2011 | 01:05 PM
AdvanZ33's Avatar
AdvanZ33
Where did you order them from?
Old Jul 16, 2011 | 01:11 PM
350Zsmokinyou
I work for american racing/wheel pros and they have been in stock here for a very long time and they finally got written off so i got them for free.
Old Jul 16, 2011 | 01:16 PM
AdvanZ33's Avatar
AdvanZ33
Nice. If you get some time, post pics. I would like to see the lip on those
Old Jul 16, 2011 | 01:21 PM
350Zsmokinyou
most definetly when i get it all put together i will post some pics
Old Jul 16, 2011 | 02:14 PM
Waiz's Avatar
Waiz
You will most likely rub in the front so you should also get the front camber kit, add some negative camber, and probably remove a portion of your front fender lining as well.
Old Jul 16, 2011 | 05:00 PM
=BANKS='s Avatar
=BANKS=
Penis ME!
you'll prob. be rubbing a bit in the back, hard to tell unless you throw them on and mess with your set up.
Old Jul 16, 2011 | 08:12 PM
dkmesa350z's Avatar
dkmesa350z
got any other Ro_Jas you could get your hands on?
Old Jul 16, 2011 | 11:34 PM
terrasmak's Avatar
As others mentioned the front may rub, no big deal and easy to deal with. Next thing is the retarded look of mounting front tires on the rear of the car, 275/30-19 is a front tire, 275/35-19 is a rear tire. It does not fill out the wheel well arch , will leave you will more fender gap, will cause VDC/TCS and minor ABS issues.
Old Jul 17, 2011 | 03:49 PM
WTFMike's Avatar
WTFMike
I have been told that they are exactly that 57s pro wheels.
Old Jul 18, 2011 | 07:23 AM
350Zsmokinyou
I run this exact set up right now with no problem at all. the goal is to keep the OD the same or as close to the same front and rear. If i ran a 275/35/19 it would put me at almost 1 inch taller then the front.
245/35/19=25.9
275/30/19=25.6
275/35/19=26.6
Old Jul 18, 2011 | 09:36 AM
terrasmak's Avatar
245/35/19=25.9
275/30/19=25.6
275/35/19=26.6
You want the rear tire to be taller than the front, that is what the electronics ar set for. Look at OEM tire heights and you will notice that. If you want the same look on the sidewall, best this to do is stagger the wheel size 19 front and 20 rear, then you will get the same sidewall height (look) without causing problems.
Old Jul 19, 2011 | 07:01 PM
Stock2Autocrozz's Avatar
Stock2Autocrozz
Similar ? I am thinking of running a separate track setup square 18x9.5 et45's w/ 285/40.
In general, I have heard positive things about square, neutral setups, w the addition of being able to rotate freely?
Any opinions?
Old Jul 20, 2011 | 07:37 AM
scotts300's Avatar
scotts300
Any opinions?
Square = good.
285/45/18 not good. I'd also try a larger wheel if you can swing it, and a 30 or 35 series on the 285 tire.
