Why put 30 series on the rear and 35 series on front?
I just got some wheels for my 2003 350Z. I got a used set of 20" Axis shine for $1300 in like new condition, 80% tread too. They look great, but I noticed that the rear tires are only 30 series and the front are 35 series.
Does anyone know why you would do that? The previous owner said they came packaged like that.
Also, the rear tires are only 275 wide, and I think a 280 or 285 would look much better, not sure why they would do that either.
I don't think it's due to rubbing, mine is at stock ride height and they rarely rub on a deep bump in the front, rear is fine though...
Thanks for any help!
Mike
Mike
hmm, sold my Axis 20 ( VIPS) for 400 bucks so dunno.
http://1010tires.com/TireSizeCalcula...p1010tires.com
you have not noted the width of your fronts, so again, dunno.
If your fronts are bigger than your rears, you are in for trouble w the VDC and/or traction control. Not sure what you have.
The profile is meaningless by itself. When you take it into account with the section width, then the picture of "why" makes more sense.
It's a way of adjusting the OD of the tire to try and maintain the same as OEM setup.
yeah if hes rollin 245 35 20 and 275 30 20 hes still bigger up front...
i ran that before, looked weak imho. Your rear size is fine OP, drop to a 30 series up front and it will look much better. btw you start getting pricey after 275 in a 20 inch tire.
Tire 1 - 245/35R20 >Search Tires Tire 2 - 275/30R20 >Search Tires
Section Width: - -
Section Width: 9.64 in 245 mm
Section Width: 10.82 in 275 mm
Rim Diameter: - -
Rim Diameter: 20 in 508 mm
Rim Width Range:
Rim Width Range: 8 - 9.5 in
Rim Width Range: 9.5 - 11 in
Overall Diameter: - -
Overall Diameter: 26.75 in 679.45 mm
Overall Diameter: 26.49 in 672.84 mm
Sidewall Height: - -
Sidewall Height: 3.37 in 85.598 mm
Sidewall Height: 3.24 in 82.296 mm
Radius: - -
Radius: 13.37 in 339.59 mm
Radius: 13.24 in 336.29
Section Width: - -
Rim Diameter: - -
Rim Width Range:
Radius: - -
People do that because
1. Clueless and just order tires that would work for most cars where the sidewall height is the same front and rear.
2. Because they want the sidewall to have the same look front and rear cause they think it looks better.
What trim level is your Z? Base? Touring?
If you have TCS or VDC, you might want to read this before you put those wheels/tires to use...
https://my350z.com/forum/showthread....1&postcount=45
Interesting.
I've driven on them for about 60miles and not even a blink of vdc/slip on the dash.
Based on those calculators my current stagger is .3"(probably more with the tread being slightly less in the rear).
If I switch to:
285/30 no stagger
285/35 1.1" stagger
275/35 .8" stagger
I think the 285/35 or 280/35 would be the best look. Is 1" of stagger too much?
Glenns280, I agree.
Terrasmak, lol.
If I switch to:
285/30 no stagger
285/35 1.1" stagger
275/35 .8" stagger
Glenns280, I agree.
Terrasmak, lol.
Thanks DavesZ, that makes a lot of sense. If I go with a 280/35/20 in the rear I will end up with .9" stagger, right in oem recommended range of 1/2"-1".
Maybe when it's time for new tires I'll do that.
Thanks for all the great info. Really helpful. I didn't even consider a lot of that.
You could be right. It's def touring. Came with the 6 spoke 18's and fully loaded.
I think I'll just up the rear to 35 series once I need a new pair. For now it doesn't look that bad, and there is a solid amount of tread left.
I'll post some pic's later tonight for you to see
Btw it's a manual, of course.
