Correct Wheel Offset?
Old Aug 23, 2011 | 08:36 AM
h2h's Avatar
h2h
Default Correct Wheel Offset?
will 19x10.5 22in offset fit correctly on the rear of my 2003z with any rub? and 19x9.5 on the front 22is offset? if so what is the correct tire size for both. I am looking at these wheels on ebay. thanks
Old Aug 23, 2011 | 08:37 AM
AroundMyHorn's Avatar
AroundMyHorn
Yes they will fit, 245/35 front and 275/35 rear (255 and 285 optional for more beef). Good day.
Old Aug 23, 2011 | 09:06 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Up front you've got more than enough room. Out back, it will depend on
1. rideheight
2. your alignment settings
3. the exact tire you run - not just the size, but the exact tire, as some run bigger than others
Old Aug 23, 2011 | 02:19 PM
Typing is atrocious. 22in? 22is? What are you taking about?
Old Aug 24, 2011 | 08:35 AM
sry110's Avatar
sry110
LOL
Anyway OP, regardless of tire brand and as long as you're in OEM camber spec, a 275/35/19 tire SHOULD fit without interfering with the rear fender lip. If anything you would need a slight fender roll to get enough clearance.
Old Aug 24, 2011 | 09:25 AM
350zion's Avatar
350zion
Professional
I run 255/285 with same offset car is dropped on a set of BC's I however cut the inner lips outta the way but I'm pretty sure they would fit without...
Also how much camber and how low play a huge factor...
I personally like the beefier look, jus got a pair of 305's to thro on next!
Tires are Bridgestone RE 11's all around....
Hope this helps Good luck, post pix!
Old Aug 24, 2011 | 12:48 PM
terrasmak's Avatar
Perfectly acceptable offsets, and leave you with many tire choices.
295/30 rear 265 or 275/30 front
305/30 rear with 275/30 front
275/35 rear with 245 or 255/35 front
285/35 rear with 255/35 front would be the more common sizing.
Old Aug 24, 2011 | 01:17 PM
Waiz's Avatar
Waiz
Please read this thread before making any additional threads:
https://my350z.com/forum/2003-2009-n...questions.html
Within that thread your question would have been answered here:
https://my350z.com/forum/2487452-post8.html
