Work VS-XX BBK Rim Clearance
Old Sep 1, 2011 | 05:38 AM
BoomerZ33's Avatar
BoomerZ33
Joel you are now a certified brake *****
Old Sep 1, 2011 | 06:39 AM
Flo-ridaZ33's Avatar
Flo-ridaZ33
After having Brembo's, Akebono's and now Endless... If your a wheel *****, your going need to be a brake ***** too. If not you'll be buying wheels that don't fit
Old Sep 1, 2011 | 01:56 PM
Ruined Z's Avatar
Ruined Z
Originally Posted by Waizzz
I don't think he was running a spacer in the front but these are his specs:
19x10 -3
19x11 +0 (I think it is now -3 but he will confirm)
That is correct, Wais! Except the fronts.
Front is now -6, but didn't need the spacers in front. I just put the spacers in to match the rear. I have A-disk in front and O-disk in the rear. Those needed a 3mm spacer and there is 1mm clearance now. Sorry, but I only have pics of my fronts (without the 3mm spacers).
Hope this helps!
Old Sep 1, 2011 | 01:58 PM
Waiz's Avatar
Waiz
Thanks for adding your info Brian
Old Sep 1, 2011 | 04:36 PM
zeebrah's Avatar
zeebrah
sweet car
Old Sep 1, 2011 | 06:00 PM
unknownkidd's Avatar
unknownkidd
Alrite the seller just comfirm that the fronts are R disk. Which mean they will clear my brakes right?
Old Sep 1, 2011 | 06:05 PM
Flo-ridaZ33
You'll need a spacer but they'll fit.
Old Sep 19, 2011 | 05:33 PM
unknownkidd
What's is the perfect offset for vs xx too clear the brakes?
Old Sep 19, 2011 | 11:48 PM
stein350z's Avatar
stein350z
hihi i think he's also wheels *****
_bit
Oct 2, 2015 07:49 AM
