Wheels & Tires Wheels, Tires, Big Brakes, Coilovers, etc...
Toyo Fall Tire Sale!!! Amazing Deals Inside!
Old Sep 22, 2011 | 04:13 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Default Toyo Fall Tire Sale!!! Amazing Deals Inside!
We've got sweet deals going for Fall on some Toyo tires
Prices include shipping in the 48 states - for any locations outside the 48 states, we'll need your full, complete address (not just the city, country or postal code please)
All are offered first come, first served.
Prices shown are for the set of 4 unless otherwise noted
If you only need 2 contact us for pricing - not all sizes can be split into 2's however
I'm posting everything we've got here, not just Z specific stuff, just in case you guys need anything for another car
T1R
The Proxes T1R is an ultra-high performance tire designed exclusively for high-end sport sedans and coupes. The Proxes T1R features a refined tread design and construction that offers improved dry and wet handling and performance. A wide range of sizes are available in V, W and Y speed ratings.
Features:
"Generation S" Silica-Reinforced, High-Grip Tread Compound - Increased silica in tread compound improves wet performance while providing excellent dry performance.
Refined Unidirectional Tread Design - Provides excellent dry and wet performance with a modern design.
V-Shaped Main Grooves - Disperse water for better wet performance.
Rigid Shoulder Rib-Bands - Improve cornering for exceptional dry performance. Reduce irregular wear for a smooth, quiet ride.
Parallel Shoulder Slits - Help reduce irregular wear
205-55-15 - 1 set left $599 shipped for the set of 4!!!!
205-55-16 - 1 set left $615 shipped for the set of 4!!!!
225-55-16 - 1 set left $689 shipped for the set of 4!!!!
235-40-17 - 2 sets left $840 shipped for the set of 4!!!!
235-45-17 - 1 set left $855 shipped for the set of 4!!!!
245-35-17 - 3 sets left $817 shipped for the set of 4!!!!
225-40-18 - 1 set left $915 shipped for the set of 4!!!!
225-45-18 - 1 set left $995 shipped for the set of 4!!!!
235-30-18 - 1 set left $982 shipped for the set of 4!!!!
235-45-18 - 1 set left $982 shipped for the set of 4!!!!
245-40-18 - 1 set left $1020 shipped for the set of 4!!!!
245-45-18 - 1 set left $1124 shipped for the set of 4!!!!
245-45-19 - 4 sets left $1294 shipped for the set of 4!!!!
R1R
An aggressive, arrowhead tread design, extra wide footprint, high-grip compound, and advanced autocross-inspired casing design, provide every advantage while driving hard through the corners and quickly accelerating in the straight-aways. It’s extreme performance for serious street driving.
•Silica reinforced high-grip compound.
•Stability control slits maintain the block stiffness during aggressive braking.
•Tapered center block edge increases center block stiffness.
•Unidirectional arrowhead shaped pattern enables excellent water drainage.
•Tapered center block edge increases hydroplaning resistance.
•Silica reinforced high-grip tread compound increases wet grip.
•Advanced autocross-inspired casing design with modified radial construction increases casing stiffness to give crisper handling.
•Multi-width EVAC channels improves water dispersion and contributes to improved steering response by narrowing towards the tire edge to widen the shoulder block area.
•Jointless bead wire.
•Wide high-tensile steel belts.
•High steel side-ply (select sizes).
•T-Mode Design Technology.
•Spiral wound cap ply.
•Computer optimized low profile design
225-50-16 – $569 shipped for the set of 4!!!!
235-40-17 – $589 shipped for the set of 4!!!!
245-40-17 – $710 shipped for the set of 4!!!!
Toyo RA-1
The performance-proven RA1 features all the high-tech components to provide an uncommon advantage to the cost-conscious competitor who still demands quick lap time. It’s true performance from Toyo!
The RA1 has a soft but durable tread compound and stepped tread design. This was the tire formerly used in the Speed World Challenge as the standardized tire.
•Advanced race-proven casing design.
•Two steel belts.
•Heavy-duty bead construction.
•Tread depth can be shaved to maximize dry traction response.
•Full tread depth of 8/32nds provides aggressive wet traction
205-40-17 - $599 shipped for the set of 4!!!!
225-40-18 - $957 shipped for the set of 4!!!!
305-35-18 - $1175 shipped for the set of 4!!!!
R888
Ideal for road racing, track days and high performance driving schools, the Proxes R888 is the next-generation, street legal competition tire from Toyo Tires. In competition the R888′s improvements in casing and tread design improve dry performance while maintaining wet traction and control.
Features:
Enhanced R-Compound Tread – Maximizes grip for better competitive handling and performance.
Unidirectional V-Shaped Tread Design – Increased tread area and limited void improves dry traction V-shaped grooves assist with wet traction.
Continuous Center Contact – Increases braking performance and dry traction.
Semi-Slick Shoulder Area – Improves grip for better steering response.
Stiff Bead Construction And Wider Tread Width – Increases cornering force for better competitive handling.
195-55-15 - $599 shipped for the set of 4!!!!
205-40-17 – $729 shipped for the set of 4!!!!
215-45-17 – $729 shipped for the set of 4!!!!
295-30-19 - just 2 tires left!!!! $710 shipped for the pair
GTR Guys
285-35-18 front, 315-30-20 rear - $1799 shipped for the set of 4!!!!
Porsche Guys
225-40-18 front, 285-30-18 rear - $1198 shipped for the set of 4!!!! Just 2 sets left
225-40-18 front, 295-30-18 rear - $1198 shipped for the set of 4!!!! Just 1 set left
To order, just give us a call, email us, or pm us with your email address
Thanks!
Old Oct 9, 2011 | 01:23 PM
Z1 Performance
Former Sponsor
up top
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
Mattg350z
Oct 2, 2015 06:51 AM
