need help: circular cut on tires inside wall?
Old Oct 21, 2011 | 11:58 AM
fifty350's Avatar
fifty350
Default need help: circular cut on tires inside wall?
I've got 3 tires blown the way, all 3 on the right front tire. for no reason the tire is literally "cut" and ripped open in a circle around the inside wall of the tire, as if a blade is touching the inside wall while driving. I'm using either 225 or 235 tires for the 3 occasions nothing fancy. Anyone had the same happened to them?
Old Oct 21, 2011 | 01:08 PM
JDMStanced's Avatar
JDMStanced
this is happening to my brother's g35 coupe with 245/35/20 front. both fronts.
i inspected the wheel well, but everything is clean and didn't find anything that could cut into the tires..
Old Oct 21, 2011 | 01:22 PM
deeno's Avatar
deeno
Jack up the car
Turn the wheel all the way to the left
Inspect
Old Oct 21, 2011 | 01:23 PM
deeno's Avatar
deeno
Dbl post
Wait...disregard the first step....get a creeper and go under the car (if it's not too low)
Old Oct 21, 2011 | 07:20 PM
This thread needs some photos.
Old Oct 22, 2011 | 01:45 AM
nismofreak1208's Avatar
nismofreak1208
Could be the weld that sits in the front fender, if you're low enough, you'll hit it and with enough force, it might just pop a tire. SOmeone here bent that weld flat against the top of the fender well though
Old Oct 22, 2011 | 03:47 PM
dab69's Avatar
dab69
crop circles
ablaine
Nov 29, 2016 10:13 AM
