Need Help Painting Wheels
Old Oct 22, 2011 | 05:33 PM
newmember's Avatar
newmember
Default Need Help Painting Wheels
hey guys, i painted my Z's stock rims today. I painted 3 of them perfectly but messed up on 1. once I messed up I decided to to strip the paint and start over, but i cant get all of the paint off. I worked on it all day and i just dont know what to do..
here a picture of it from my phone...
I need my car on monday, I dont want to drive with 1 screwed up rim. Please tell me how to get the rest of the paint off...
Old Oct 22, 2011 | 05:45 PM
Steve@Captive's Avatar
Steve@Captive
Vendor - Former Vendor
You're wet sanding correct?
Old Oct 22, 2011 | 05:57 PM
newmember's Avatar
newmember
dry sanding...
Old Oct 22, 2011 | 05:59 PM
Steve@Captive
Wet sand until their smooth, then paint. When I repainted my rims some paint was still on them as long as it's completely smooth you should be fine. Mine came out good.
Old Oct 22, 2011 | 06:06 PM
newmember's Avatar
newmember
what grit should I use?
Old Oct 22, 2011 | 06:15 PM
Steve@Captive
Don't remember exactly mine had 3 layers of paint and 3 layers of clear coat along with primer, so I used a very aggressive grit and then started getting less and less aggressive until it was perfectly smooth.
Old Oct 22, 2011 | 06:56 PM
JZ33's Avatar
JZ33
use 1200 or if you feel thats too much use 1500... that should get it smooth, you dont need to get all the paint off, especially if you are painting over it the same color. Just like Steve said, get it smooth and you will be fine
Old Oct 22, 2011 | 09:03 PM
You can always rent a sandblaster.
Old Oct 22, 2011 | 09:57 PM
beezee's Avatar
beezee
also keep checking eBay or c'list in your area for a used single and start over. should not cost much and saves the hustle
Old Oct 22, 2011 | 11:34 PM
User 42426's Avatar
User 42426
did u try paint stripper?
Old Oct 23, 2011 | 12:07 AM
scoobyrex247's Avatar
scoobyrex247
go to lowes or home depot buy chemical paint remover. Buy some latex gloves and special 1.5in circular wire drill bit .
Attach drill to any cordless / corded power drill and spray the rim with the remover. I did ea rim in 15 min ea. Took it to the bare alloy. Sand with 320 grit, Primer then wed sand with 800 or 1000. Tack cloth it. Ready for rattle can.
My 14.4 volt hitachi drill made short work of the oem finish. I even use really harsh rim cleaner on the rattle can finish and no chips or paint damage. Epic right?
The paint remover may come in a aerosol or buy a plastic spray bottle.
