need help with wheel size choices....
Old Oct 27, 2011 | 02:17 PM
gotmeaZ's Avatar
gotmeaZ
Default need help with wheel size choices....
SO im looking at some xxrs. i was at first going to do
18x8.5 +25 in the front
18x10 +25 in the rear
225/45/18
245/45/18
but now.. im thinking about going with a square setup.. (i know nothing about sqaure setups)...
i wanted to do
18x10 +25 all around.
i really just want to know a few things..
1. what size tires would be the best fit for 18x10??
2. would 18x10 all around require a roll/pull?
3. would 18x10 sit flush? maybe add a 20mm spacer in the front, and 10mm in the rear?
4. im lowered about 1 inch.. would i need any sort of camber kit? will a sqaure setup on stock suspension cause any harm?
thanks and please bare with me.. im learning as i go!
Old Oct 27, 2011 | 02:39 PM
SE5spd's Avatar
SE5spd
225/45/18
245/45/18
i wanted to do
1. what size tires would be the best fit for 18x10?? 275/35/18 atleast.
2. would 18x10 all around require a roll/pull? yes if you are lowered.
3. would 18x10 sit flush? maybe add a 20mm spacer in the front, and 10mm in the rear? if you are going for flush do a 15MM spacer all around
4. im lowered about 1 inch.. would i need any sort of camber kit? will a sqaure setup on stock suspension cause any harm? get a camber kit. If you are lowered why are you asking about stock suspension?
read bold.
Old Oct 27, 2011 | 05:07 PM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
18x10+25 will sit almost flush in the front if you aren't lowered but you will need at least a 15mm spacer in the rear to match the front. Tires selection is up to you and what your goals are. As far as the width of the tire goes, 255 has a very mild stretch, 265 is perfectly square IMO and 275+ I would consider fat. The aspect ratio of the tire will determine your wheel gap. Plan on rolling the rear fenders if you use spacers.
Obadabot
Jun 18, 2023 11:31 PM
