wheel and tire guys help plz
Old Dec 19, 2011 | 07:26 PM
Cheffy916's Avatar
Cheffy916
Default wheel and tire guys help plz
Just bought my 350Z about a month ago and i saved up enough money for new wheels and tires. i was looking at some wheels that are 19x8.5 in the front with et18 and 19x9.5 rear with e21 will this fit without me having to roll the fenders my z is not lowered yet. and what tires should i get? any help is much apriciated. thanks.
Old Dec 19, 2011 | 07:35 PM
Cheffy916's Avatar
Cheffy916
bump
Old Dec 19, 2011 | 07:38 PM
ambushphoto's Avatar
ambushphoto
i run 19x8.5 and 19x10 with 245/40 and 285/35 w/ no issues, not lowered, no fender roll.
Old Dec 19, 2011 | 07:45 PM
jerseystyle's Avatar
jerseystyle
You're seriously going to bump it 9 minutes after posting? Seriously? If you need help with wheels/tires, why didn't you post in here:https://my350z.com/forum/wheels-and-tires-60/ The "Wheel/Tire" tech section?
This has been discussed numerous times. Try doing a search of the appropriate section.
Old Dec 19, 2011 | 08:44 PM
Waiz's Avatar
Waiz
Jeebus...
Read this thread to answer your question:
https://my350z.com/forum/2003-2009-n...questions.html
https://my350z.com/forum/2487452-post8.html
Here are some of the more popular wheel and tire sizes (for good reason) that people put on their Z's. There is no "RIGHT" answer but there is a limit to how big or small you can go.
18" combination:
Front 18" x 8.5" , Offset +15 to +25, Tires 245/40/18
Rear 18" x 9.5" , Offset +15 to +25, Tires 275/40/18
(lower offset such as +10 in rear is possible but may require rolling)
Front 18" x 9.5" , Offset +25 to +30, Tires 255/40/18
Rear 18" x 10.5" , Offset +28 to +35, Tires 285/40/18 or 295/35/18
(lower offset such as +23 in the rear is possible but may require rolling)
19" combination:
Front 19" x 8.5" , Offset +15 to +25, Tires 245/35/19
Rear 19" x 9.5" , Offset +15 to +25, Tires 275/35/19
Front 19" x 9.5" , Offset +25 to +30, Tires 255/35/19 or 265/35/19
Rear 19" x 10.5" , Offset +23 to +32, Tires 285/35/19 or 295/35/19
(lower offset such as +23 or wider tires in the rear is possible but may require rolling)
From this, you get the idea of what is required to go with smaller wheels like 17's, (typically lighter, faster acceleration), or bigger wheels like 20's (bigger, heavier, usually makes you feel slower).
Get to know how to use the following tools and you will be able to figure out for yourself the correct offsets and tire sizes you need:
Tire size calculator (click)
Wheel Offset Calculator
Certain combinations of LOW OFFSET and/or WIDE WHEELS will require what is known as "fender rolling" or "fender cutting".
Old Dec 19, 2011 | 09:10 PM
terrasmak's Avatar
It will fit
May 30, 2017 03:28 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
Tochigi_236
Sep 27, 2015 03:40 PM
samansharif
Sep 25, 2015 12:31 PM
