best budget rims?
Old Dec 25, 2003 | 04:38 AM
b3n84's Avatar
b3n84
Default best budget rims?
Is there such a thing? After a wallet-exhausting X-Mas, plus the death of my computer, I don't have a lot of $$ left for buying a costly set of wheels (costly to me means: $500+ per rim). I'm buying rims less for the fact of making myself stand out, but more because I bought blizzaks and mounted them on my badly-curbed rims (too long of a story to explain) and I figured it'd be smarter to get new rims and tires instead of switching between blizzaks and my old tires.
I live in NYC [pot-hole city] so I need something durable. Other than that, I have pretty low standards (although I want the rims to be at least 18"). Any suggestions? I did a few searches on budget rims and the like and not much popped up. Thanks guys (and gals)!
Old Dec 25, 2003 | 05:05 AM
Apexi350z's Avatar
Apexi350z
Charter Member #50
You can start by searching the wheels/tires section, or if you don't want to go through all the threads, then you can check out Discount Tires online, they have lots of selections on all kinds of budgets. I bought my Privat Fahren from Discount Tires and I couldn't be any happier! It's around $250 range....
Old Dec 25, 2003 | 05:45 AM
devildoc's Avatar
devildoc
There are tons of choices for rims with out dropping 3k on a set. I'm kinda in the same situation. Check out
tirerack
wheelmax
Another good source, the import magazines. Go to your local book store and look through a couple of them. They've got quite the selection and you can even find some good deals.
Good luck
Ian
Old Dec 25, 2003 | 05:52 AM
ares's Avatar
ares
Veteran
you might want to grab a set of 17's. they are VERY cheap, 4-500$ for a set with tread. cant beat that with a stick.
18" gets a bit pricier at about 800; but still with tread thats way cheaper than youll find any other set of rims and tread.
your better to say how much you can spend. volk has a few sets of rims that run around 1200 a set; not quite 2-3000. but might still be higher than you were looking for.
Old Dec 25, 2003 | 06:28 AM
SHAQMAGIC's Avatar
SHAQMAGIC
ADR makes real nice wheels and you can get 18's for between 600-950 for the four of them depending on which ADR rim you go with.
The two I've seen on Z's are the ADR M-Sports and the ADR Sterlings. Both wheels look dynamite on the car.
Of course, I'm biased because I have ADR's but it's nice to know I got my rims for what some people spend on one wheel.
PM for pics.
Old Dec 25, 2003 | 07:24 AM
themyst's Avatar
themyst
Default Re: best budget rims?
if you want to mount snow tires, buy a set of used stock 18" wheels on these forums. it will cost you no more than 700-800 for the set w/o tires and u can swap your snow tires out with stocks whenever you want.
Old Dec 25, 2003 | 07:32 AM
Apexi350z's Avatar
Apexi350z
Charter Member #50
also, I think hopupracing is selling some 18" 5zigen wheels for around $1000.00, those are very light 5 spoke wheels, my buddy just got one for his G35c, and they look awasome!
Old Dec 25, 2003 | 11:54 AM
b3n84's Avatar
b3n84
I'm looking to spend about 1500 for new rims + tires. I know there are a lot of cheap rims out there. I'm just wondering what are the higher quality rims that don't carry the heavy price tag. Rims with good durability and make. (forged rims are supposedly to be the strongest right?)
Old Dec 25, 2003 | 01:44 PM
ssk0771's Avatar
ssk0771
How about 5Zigens Corpse? The are very nice and I use to have them and they are very durable. They are also made in Japan by 5 Zigens.
Old Dec 25, 2003 | 03:02 PM
mrZeee's Avatar
mrZeee
try these guys
http://www.aaarims.com
refurbs, but cheap..thinkin of getting g35 18's from 'em
Old Dec 25, 2003 | 06:04 PM
NY 350Z's Avatar
NY 350Z
i drive to queens for school,im worried about the same thing. But i guess if i go from 17's to 18's it wouldnt really be any worse.
Old Dec 25, 2003 | 07:15 PM
zillinois's Avatar
zillinois
NISMO are perfect at that price. You can find them for even less than $500 a pc. sometimes.
https://my350z.com/gallery/albun28/aaa
Old Dec 25, 2003 | 08:40 PM
ares's Avatar
ares
Veteran
500 a peice yes; thats 2000 by themselves and another grand for tires.
as for your goal; I dont think that will be possible if I am understanding you right. 1500 for rims AND tires? or for rims; and then whatever for tires? sounded like the former; and with 18" tires running atleast 600$ for a set; and in many cases closer to 1000; that leaves very little for the rims.
forged rims will run you ATLEAST 400$ each in the 18" variety; they are the highest quality rims for the most part; and if they werent that much; Id reccomend not getting them. there are the "designer" makers like HRE which might charge a slight premium for the name. but there are not really any "bargain" brands that just put out a better all around rim for less then the competition; as with most things, you get what you pay for.
Old Dec 26, 2003 | 01:11 AM
zillinois's Avatar
zillinois
1859.00 shipped.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2449437405
Old Dec 26, 2003 | 08:29 AM
b3n84's Avatar
b3n84
Would it be ok if I were to keep my stock tires and mount them on new rims? My stock tires are the G35 pilot sports 245/45/18, 225/45/18. I heard from some that putting it on new rims may stretch them too thin.
Old Dec 26, 2003 | 09:02 AM
zillinois's Avatar
zillinois
You can swap tires, I did it with my Potenzas. Be careful who does it, because the rims are easy to scratch.
Old Dec 26, 2003 | 09:10 AM
ares's Avatar
ares
Veteran
depends what rim size you get; and how much distortion you find acceptable. 245 can fit all the way up to 9.5 or 10" rim; but its gonna look and ride wierd. whether its safe or not; I donno.
if you plan to get 8.5 or 9" rims tho; you would be ok IMO to use the 245. youll find most sets go 8.5 in front and 9.5 in rear; so youd if anything have a better shot at just using the rear tread on the new front rims; and buying a new set of 275(~500$) for the rear. you will be a bit large on the profile; but it will be ok if you go 45series on the rear too and switch to 40 series all around when you replace all 4 tires down the road.
now was that confusing?
Old Dec 26, 2003 | 09:14 AM
lowrider's Avatar
lowrider
Not a good idea to keep stock tires on the wider Nismo wheels. 225/45/18 recommended rim size is 7.5", recommended rime range is 7 to 8". Nismos are 8.5" front. 245/45/18 recommend rim width is 8", recommended rim range is 7.5 to 9", Nismos are 9.5" front. So, not recommended by tire manufacturers. But as you can see, some people have done it.
They might leak, or they might let go in a spirited turn. I put a set of Dunlop SP9000s on mine. Got them from a local discount tire store, mounted balanced with sales tax for $909.00.
Lou
Old Dec 26, 2003 | 10:23 AM
zillinois's Avatar
zillinois
Good point.
Old Dec 27, 2003 | 09:36 PM
b3n84's Avatar
b3n84
The Copse sounds like a great fit for what I'm looking for. Going to start researching it right now. Thanks for all your suggestion guys! (and girls) If anyone has any ideas/comments on the Copse, feel free to share. Do you think my stock tires will fit on the Copse?
