How do I know which Aftermarket wheels will work with the Tire pressure sensors?
Old Dec 25, 2003 | 02:43 PM
Static's Avatar
Static
Default How do I know which Aftermarket wheels will work with the Tire pressure sensors?
I heard only certain aftermarket wheels will work with the 350z tire pressure sensors. How do I find out if a wheel will work?
Old Dec 25, 2003 | 03:08 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
NISMO LMGT4's do...
others... cant guarantee...
Old Dec 25, 2003 | 03:15 PM
MSOsr's Avatar
MSOsr
All should work if the sensor is mounted to the wheel (e.g., with an HRE band). Use the search function here......someone did a thread of how to mount the tire sensors to any wheel.
Old Dec 25, 2003 | 06:36 PM
ssk0771's Avatar
ssk0771
SSR GT3 will work with tire pressure sensor.
Old Dec 26, 2003 | 05:10 AM
ChinaClipper's Avatar
ChinaClipper
Default Re: Which Aftermarket wheels will work with the Tire pressure sensors?
On the assumption that your question is asking how to fit the stock TPSs to aftermarket wheels in a manner that their function and installation is identical, the obvious answer is to obtain a TPS and test fit it to the wheel you are thinking of using. Basically, not all aftermarket wheel makers design their valve stem mounting hole in the rim the same. Some wheels, like Volk GT7 (IIRC), have their valve holes mounted in the exact center of the rim and need a special, unique "elbow" valve stem design. Other wheels like the fancier Modas with the set-screw three-piece wheel look, hide the valve stem behind a faux set screw head - which will prevent installation of a TPS thru the rim. The stock TPS requires a configuration such that the body of the TPS lies flat against (or nearly parallel with) the "valley" of the wheel rim. See picture for illustration.
HTH.
Attached Thumbnails How do I know which Aftermarket wheels will work with the Tire pressure sensors?-tire-pressure-sensor.jpg
Old Dec 26, 2003 | 05:44 AM
MSOsr's Avatar
MSOsr
Here's the link to attaching the sensors to any aftermarket wheel that won't allow the sensor to be mounted like stock:
https://my350z.com/forum/showthread....ssure+and+band
JjL
East Canada
Jun 12, 2019 03:04 AM
rizzla
Sep 29, 2015 03:58 PM
Shane86
Sep 17, 2015 05:33 PM
Calinismo350z
Sep 14, 2015 04:04 PM
speedsniper
Sep 14, 2015 08:46 AM
