Wheels & Tires Wheels, Tires, Big Brakes, Coilovers, etc...
Killer Deal on an Amazing Tire
Old Jan 20, 2012 | 10:24 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Default Killer Deal on an Amazing Tire
Toyo R1R –
An aggressive, arrowhead tread design, extra wide footprint, high-grip compound, and advanced autocross-inspired casing design, provide every advantage while driving hard through the corners and quickly accelerating in the straight-aways. It’s extreme performance for serious street driving.
•Silica reinforced high-grip compound.
•Stability control slits maintain the block stiffness during aggressive braking.
•Tapered center block edge increases center block stiffness.
•Unidirectional arrowhead shaped pattern enables excellent water drainage.
•Tapered center block edge increases hydroplaning resistance.
•Silica reinforced high-grip tread compound increases wet grip.
•Advanced autocross-inspired casing design with modified radial construction increases casing stiffness to give crisper handling.
•Multi-width EVAC channels improves water dispersion and contributes to improved steering response by narrowing towards the tire edge to widen the shoulder block area.
•Jointless bead wire.
•Wide high-tensile steel belts.
•High steel side-ply (select sizes).
•T-Mode Design Technology.
•Spiral wound cap ply.
•Computer optimized low profile design
225-50-16 – $569 shipped for the set of 4!!!!
235-40-17 – $589 shipped for the set of 4!!!!
245-40-17 – $699 shipped for the set of 4!!!!
No other sizes are available. Price includes shipping in the 48 states. Worldwide shipping is available, contact us with your exact address for details. Bulk discounts available when shipped to a single address as well, and staggered setup with the above sizes also offered
Call us at (631)863-3820 to order
