'06 350z Wheels
Hello everyone,
I'm a relatively new poster here and I'm looking for some advice on wheels. I've got a 2006 Grand Touring Coupe with everything being stock; the wheel measurements for this are as follows: FRONT: 18x9 +30mm Offset and REAR: 19x10 +30mm Offset. You all may already know this, but I'm just throwing it out there. I'm thinking about buying a set of XXR wheels that have measurements that are as follows:FRONT: 18x9 +25mm Offset and REAR: 18x10.5 +20mm Offset. The bolt pattern matches up at a 5x114.3.
Basically, I'm wondering if these will fit on my car well. If so, will there be any noticeable changes to how far the wheels poke out?
Thanks for the help!
-- Osr
-- Osr
The front will stick out roughly 5mm more and the rear will be much more noticeable at 16mm. I suggest getting 10mm spacers for the front if you're set on those sizes. Depending on your tire sizes, you might need a slight fender roll in the rear.
BTW, I would rather keep the stockers than replace them with XXR wheels.
Welcome.
Use a offset calculator to compare your current wheels to the new wheels. With the new dimensions, check the car with a tape. Do you clear the suspension, brakes calipers and fenders? Reference: http://www.1010tires.com/WheelOffsetCalculator.asp
Read this thread:
https://my350z.com/forum/2003-2009-n...questions.html
Your question would have been answered within it here:
https://my350z.com/forum/2487452-post8.html
hardkicks
Sep 20, 2015 12:28 PM
VQA33
Wheels Tires
Sep 8, 2015 08:30 PM
