Please help with specs/ offsets, etc.!!
Old Jun 20, 2012 | 05:00 PM
huanandonly's Avatar
huanandonly
Default Please help with specs/ offsets, etc.!!
Hey guys, i'm a newbie here so bear with me. I want to look into getting some Work Emotion CR Kiwami wheels in 18" for my 2007 Z ...but I am not sure about the specifics of my options. I have included a screen grab of the specs from the Work site on these wheels and I am asking for your guys' help in figuring out what would be the "best" staggered set-up for my ride.
I am trying to keep it as close to stock as possible because it's not that important for me to have it hella-flush (would be nice though) ...and i don't want to necessarily mess with a fender roll either.... so, from the specs of these wheels, what would be the best choice combination in the 18"?... in the front and rear wheels?... offsets?
ANY insight into this would be greatly appreciated! thanks!
Attached Thumbnails Please help with specs/ offsets, etc.!!-0.97280500-1300062423_410.jpg   Please help with specs/ offsets, etc.!!-screen-shot-2012-06-20-at-4.48.04-pm.jpg
Old Jun 20, 2012 | 05:17 PM
mattleegee's Avatar
mattleegee
Most people buy +12 on 9.5 front and 10.5 rear combos for a little poke
and +22 for a more flush look
So for these a guy would figure
+20 on 9.5 front
+23 on 10.5 rear is only option, and that should be flushish
i dont know much of anything about offsets, i just read alot of threads
Old Jun 20, 2012 | 06:04 PM
Waiz's Avatar
Waiz
Wowzers, please read the Top 100 FAQ:
https://my350z.com/forum/2003-2009-n...questions.html
If you would have searched/viewed that thread it would have yielded you the following:
Q: What wheel sizes and offsets do I need?
A: Generally speaking, there are a LOT of different combinations that people are running on their Z or G.
Let's get the basics out of the way first: You need a lug pattern of 5x114.3, width between 8 and 11 inches, and diameter of 17", 18", 19", or 20".
Here are some of the more popular wheel and tire sizes (for good reason) that people put on their Z's. There is no "RIGHT" answer but there is a limit to how big or small you can go.
18" combination:
Front 18" x 8.5" , Offset +15 to +25, Tires 245/40/18
Rear 18" x 9.5" , Offset +15 to +25, Tires 275/40/18
(lower offset such as +10 in rear is possible but may require rolling)
Front 18" x 9.5" , Offset +25 to +30, Tires 255/40/18
Rear 18" x 10.5" , Offset +28 to +35, Tires 285/40/18 or 295/35/18
(lower offset such as +23 in the rear is possible but may require rolling)
19" combination:
Front 19" x 8.5" , Offset +15 to +25, Tires 245/35/19
Rear 19" x 9.5" , Offset +15 to +25, Tires 275/35/19
Front 19" x 9.5" , Offset +25 to +30, Tires 255/35/19 or 265/35/19
Rear 19" x 10.5" , Offset +23 to +32, Tires 285/35/19 or 295/35/19
(lower offset such as +23 or wider tires in the rear is possible but may require rolling)
From this, you get the idea of what is required to go with smaller wheels like 17's, (typically lighter, faster acceleration), or bigger wheels like 20's (bigger, heavier, usually makes you feel slower).
Get to know how to use the following tools and you will be able to figure out for yourself the correct offsets and tire sizes you need:
Tire size calculator (click)
Wheel Offset Calculator
Certain combinations of LOW OFFSET and/or WIDE WHEELS will require what is known as "fender rolling" or "fender cutting".
If you are not familiar with the term "fender rolling", here is a quick but useful lesson you can learn in a couple of minutes: Go outside to wherever your Z is parked. Run your fingers along the inside edge of a REAR fender just above your tires. You will feel a sharp edge and a flap of metal sticking inward towards the car. Now, go up to the FRONT fender, and feel the inside of the fender again. You should notice that the flap of metal has been "rolled" upwards on the front fenders. This is exactly what fender rolling is all about. The rear fenders will need to be rolled to make room for wide wheels or low offsets, or else your tires may rub on the metal when you take hard corners or hit bumps. Any experienced wheel/tire shop should know how to roll a fender. If you go to a shop that does not seem like they know what they're doing, get out of there.
Before making any future threads please read the Top 100 FAQ and or conduct your own search, it's not rocket science you just need to do your homework
Tochigi_236
Sep 27, 2015 03:40 PM
