Need help with NISMO long hub bolts
Old Jan 12, 2004 | 01:25 PM
zillinois's Avatar
zillinois
Default Need help with NISMO long hub bolts
Would someone be willing to measure the width of their wheel studs on a car with 17" rims? I need to know the diameter of the knurled part of the stud.
There are two sizes listed at Performance and Courtesy parts - 13mm and 14.3mm. I ordered the 13mm which is supposed to be the correct size but it does not fit my performance model. I want to sell them, but I need to what car these will fit. My theory is that cars with 18" rims use the bigger studs and cars with 17" use the smaller. But I need someone to check. Thanks
Old Jan 12, 2004 | 04:24 PM
Audito350Z's Avatar
Audito350Z
I'm measuring one right now that would work on the Track model Z and it sure is closer to 15mm than 13mm, so I'd say it's 14.3mm... I'm using a cheap plastic ruler, not a caliper, so I'm not getting 100% accurate here
Hope that helps,
PeteH
Old Jan 12, 2004 | 04:45 PM
zillinois's Avatar
zillinois
Thank you. I wonder if all Z's 14.3mm then.
Old Jan 12, 2004 | 11:09 PM
350ed's Avatar
350ed
Professional
They're all 14.3mm. I did the same thing and returned for the other size.
sales@czp
Sep 23, 2019 03:30 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
