Powdercoating Wheels
Old Dec 28, 2012 | 04:49 PM
NC Z's Avatar
NC Z
Default Powdercoating Wheels
Hey guys, I was thinking about powder coating my stock rims on my z. Is that a good idea or no? Also, if I decide to get rid of a powder coat, is that possible? And if I did remove the powder coat, would the rims look the way they did before the coating? Thanks
Old Dec 28, 2012 | 05:02 PM
VMRWheels's Avatar
VMRWheels
Vendor - Former Vendor
You have to strip the existing finish off of the wheels before they can be powder coated. Powder coating is pretty good for wheels since the finish is generally quite durable. Ultimately though it's up to you if you think it would be worth it. You'll basically need to strip the wheel down to the bare metal again if you want to refinish them again. I also wouldn't recommend powder coating wheels more than a couple times, as it could potentially make the wheel more brittle when heat cycled like that.
Old Dec 28, 2012 | 05:05 PM
NC Z's Avatar
NC Z
Thanks for clearing that up for me
Old Dec 28, 2012 | 06:27 PM
mike_eee's Avatar
mike_eee
sorry to hijack the thread, I have Nismo LMGT4 powder-coated in black and I am planning to coat it again cause the finish is not good..would it affect it...these are forget mono block wheels made by volks
mike
Old Dec 28, 2012 | 07:09 PM
ph240's Avatar
ph240
You do have to prep them correctly but p/c holds up very well on wheels if applied properly.
Properly means professionally. A diy kit with e z bake oven probably wont work properly. There are several companies in NC that can do it properly, one in Mooresville that I have used several times.
Old Dec 29, 2012 | 07:35 AM
SQuaLZ's Avatar
SQuaLZ
Powdercoated gunmetal. Really sparkles in the sun.
Old Dec 31, 2012 | 08:55 AM
VMRWheels's Avatar
VMRWheels
mike
You could probably get them coated again, just make sure that the place you take them to has experience powder coating wheels.
