Hub bore?...
Old Mar 8, 2013 | 10:07 PM
VqBrickYard's Avatar
VqBrickYard
Default Hub bore?...
Will a hub bore 73.1 fit flush on to my 2003 Z or will It require something? Please and thank you for your replies
Old Mar 8, 2013 | 11:26 PM
Jets350's Avatar
Jets350
Considerring Z's have 66.1.. should have to run rings to reduce vibration
Old Mar 9, 2013 | 03:40 AM
Bmurray350z's Avatar
Bmurray350z
yeah you'd want these
http://www.ebay.com/itm/4-NEW-OD-73-...ca2815&vxp=mtr
Old Mar 9, 2013 | 05:03 AM
sofa king's Avatar
sofa king
expect vibration at higher speeds without those.
Old Mar 9, 2013 | 09:00 AM
VqBrickYard
That's what I was afraid of, thank you so much guys for your help. So with these rings no vibration at all at high speeds?. One last question of I would like for the rims to stick out more I would need spacers?... By the way I'm getting Xxr522, going to run 235-30-19 front 265-30-19 rear 19"x8.5" front 19"x10"rears. What do you guys think?
Old Mar 9, 2013 | 10:16 AM
Jets350's Avatar
Jets350
For the rim to stick out past the fenders.. you'd need to run spacers. but if the rims are past the fender,. you'd need to stretch. try running a wider rim if you want that look because the most stretched you could pull out of an 8.5 / 10, would probably be around a 215 and a 225-235.. which are extremely skinny.
Old Mar 9, 2013 | 11:39 AM
VqBrickYard
Okay that makes more sense, when you talk about stretch what do you mean specifically?
Old Mar 9, 2013 | 12:31 PM
Bmurray350z
you dont want the wheels past the fenders.. wtf. you want them flush with the fenders. you will need spacers if you want them to be flush with the fenders. and when he says stretch he means this stupid phad where people stretch a 245mm wide tire on a 12" wide wheel.
Old Mar 9, 2013 | 12:53 PM
VqBrickYard
Alright then, I wouldn't want to go through all that trouble I'll play it safe with making sure the wheels do align good with the fenders. If anything I'll have my fenders rolled I'll try them on tonight. Should have pics up.
Old Mar 9, 2013 | 12:54 PM
Bmurray350z
just get everything on. get it aligned, then see what size spacers you need.
EnjukuRacing
Sep 30, 2015 06:55 AM
