BFG Sport Comp 2s
Old Mar 18, 2013 | 06:09 PM
Sunset350ZR's Avatar
Sunset350ZR
Default BFG Sport Comp 2s
Ok I have bought these tires in 245-40 and 275-40 with 18 inch diameter. I came from a NT-05 previously and the FK-452s before that. The Nottos were world's better than the Falkens in every parameter . So does anyone have the Sport Comp 2s and what should I suspect?
Old Mar 20, 2013 | 06:25 AM
neal@tirerack's Avatar
neal@tirerack
Vendor - Former Vendor
I can't say for certain how they compare to those other two brands as we do not carry them. However, they have done really really well overall. The dry traction and steering response is top in its class and they actually wear really well. Haven't had any complaints on them.
Old Mar 20, 2013 | 07:18 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
<~ Will never own a set of Nittos. I will be running the Sport comp-2's on my G37S though.
Old Mar 20, 2013 | 07:43 AM
pangoman's Avatar
pangoman
I just put the Sport Comp 2's on my Z. They replaced the Hankkok Ventus V12's. I found that teh Hankooks weren't bad in regards to wear and traction (wet and dry). What I didn't like about the Hankooks were that the sidewalls were soft. I had to run them between 36 - 38 psi front and rear respectively. Once I had the new BFG's mounted I had them inflate to 36 - 38 psi. I am happy to say that I lowered the tire pressure to the normal 32 psi for both front and rear and they feel great! Sidewalls are not soft like the Hankooks. Traction for both wet and dry have not been an issue thus far. Now to see how they wear. I expect the BFG's to have better wear as their wear rating is quite a bit higher.
seagrasser
Oct 11, 2015 03:27 PM
