Tire Pressure Sensors -reset vs. move
Old Jan 20, 2004 | 08:38 AM
SA-Z's Avatar
SA-Z
Default Tire Pressure Sensors -reset vs. move
Hi, my TPS are incorrectly setup - with the Fronts showing the front left and the right rear, And the Rear showing the Left rear and the Right front.
Should i have the dealer re-set them to read correctly (Is this something the dealer would do?), or is it easier to swop the sensors when I have the tires replaced. (Will need to dismount and remount the right front after swopping the sensors. )
Thanks
Old Jan 21, 2004 | 06:13 PM
No PRNDL's Avatar
No PRNDL
Just had to do the same this weekend. Have the dealer reset. It's much better than breaking the beads again on the tires. The process is simple. Set left front to 37psi, right front to 34psi, right rear to 31 psi, and left rear to 28psi. The dealer can hook up a diagnostic unit (called Consult II) and by pushing a few buttons and driving around for a few minutes, the system identifies each corner by its PSI setting and locks it in memory. Readjust pressure to normal and your on your way!
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
sales@czp
Sep 23, 2019 03:30 PM
