Wheel Size and Offset Suggestions
Old Apr 1, 2013 | 04:24 PM
Trevor Hebert's Avatar
Trevor Hebert
Default Wheel Size and Offset Suggestions
What would yall recommend for a rim size and offset. Want to fill in the fender, but not use any spacers
Old Apr 1, 2013 | 04:45 PM
vex008's Avatar
vex008
**IN**
Old Apr 1, 2013 | 05:17 PM
DavesZ#3's Avatar
DavesZ#3
Check out the Top 100 Questions thread linked in my sig. Plus, you want to browse the Wheel/Tire forum here... https://my350z.com/forum/wheels-and-tires-60/
Probably the most common setup is 19" 9½/10½ +22.
Old Apr 1, 2013 | 05:36 PM
Trevor Hebert
Do you think +13 offset will work for a Z?
Old Apr 1, 2013 | 06:32 PM
HanoverZ's Avatar
HanoverZ
Seems to between +18 and +22, +22 being most common. +13 would probably be fine. Should've searched though... people ask this all the time.
Old Apr 1, 2013 | 06:33 PM
Trevor Hebert
What would be the difference in +15, and +13 offset?
Old Apr 1, 2013 | 07:15 PM
terrasmak's Avatar
2mm is the difference
Old Apr 1, 2013 | 07:21 PM
SR71's Avatar
SR71
Lead Super Moderator
ll
That much
Old Apr 1, 2013 | 07:25 PM
Trevor Hebert
2mm, good or bad kind of difference?
Old Apr 1, 2013 | 08:12 PM
zJames's Avatar
zJames
good go lower
Old Apr 1, 2013 | 08:32 PM
terrasmak's Avatar
Do you know how much 2mm is ? Look at a ruler.
Old Apr 1, 2013 | 08:52 PM
Waiz's Avatar
Waiz
Do yourself a favor and like Dave stated read this entire thread:
https://my350z.com/forum/2003-2009-n...questions.html
Then read this post
Q: What wheel sizes and offsets do I need?
A: Generally speaking, there are a LOT of different combinations that people are running on their Z or G.
Let's get the basics out of the way first: You need a lug pattern of 5x114.3, width between 8 and 11 inches, and diameter of 17", 18", 19", or 20".
Here are some of the more popular wheel and tire sizes (for good reason) that people put on their Z's. There is no "RIGHT" answer but there is a limit to how big or small you can go.
18" combination:
Front 18" x 8.5" , Offset +15 to +25, Tires 245/40/18
Rear 18" x 9.5" , Offset +15 to +25, Tires 275/40/18
(lower offset such as +10 in rear is possible but may require rolling)
Front 18" x 9.5" , Offset +25 to +30, Tires 255/40/18
Rear 18" x 10.5" , Offset +28 to +35, Tires 285/40/18 or 295/35/18
(lower offset such as +23 in the rear is possible but may require rolling)
19" combination:
Front 19" x 8.5" , Offset +15 to +25, Tires 245/35/19
Rear 19" x 9.5" , Offset +15 to +25, Tires 275/35/19
Front 19" x 9.5" , Offset +25 to +30, Tires 255/35/19 or 265/35/19
Rear 19" x 10.5" , Offset +23 to +32, Tires 285/35/19 or 295/35/19
(lower offset such as +23 or wider tires in the rear is possible but may require rolling)
From this, you get the idea of what is required to go with smaller wheels like 17's, (typically lighter, faster acceleration), or bigger wheels like 20's (bigger, heavier, usually makes you feel slower).
Get to know how to use the following tools and you will be able to figure out for yourself the correct offsets and tire sizes you need:
Tire size calculator (click)
Wheel Offset Calculator
Certain combinations of LOW OFFSET and/or WIDE WHEELS will require what is known as "fender rolling" or "fender cutting".
If you are not familiar with the term "fender rolling", here is a quick but useful lesson you can learn in a couple of minutes: Go outside to wherever your Z is parked. Run your fingers along the inside edge of a REAR fender just above your tires. You will feel a sharp edge and a flap of metal sticking inward towards the car. Now, go up to the FRONT fender, and feel the inside of the fender again. You should notice that the flap of metal has been "rolled" upwards on the front fenders. This is exactly what fender rolling is all about. The rear fenders will need to be rolled to make room for wide wheels or low offsets, or else your tires may rub on the metal when you take hard corners or hit bumps. Any experienced wheel/tire shop should know how to roll a fender. If you go to a shop that does not seem like they know what they're doing, get out of there.
Closed so you can read and actually do some of your own research
Pleask
Dec 21, 2021 03:17 PM
burglapfd
Dec 6, 2020 01:04 PM
ablaine
Nov 29, 2016 10:13 AM
Depravity
Oct 1, 2015 04:49 PM
