One quick question about tire size
Old Jun 12, 2013 | 06:02 AM
aRYip's Avatar
aRYip
Default One quick question about tire size
I have 18x8.5 front and 18x9.5 rear
And I am looking to buy 235/40/18 for front and 275/35/18 for rear
Is there any issues with this set up? as I check them only 0.7 differences.
Don't know if this is VDC happy setup.
Old Jun 12, 2013 | 07:58 AM
Jbakes727's Avatar
Jbakes727
I also have a tire question I was thinking of running 225/35/19 front and 255/35/19 rear. Will this work with the car? I have an 04 enthusiast (17")
Old Jun 12, 2013 | 08:18 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
You may see a SLIP light under aggressive driving because your rear tire would only be a couple millimeters taller than the front.
It will work (not on 17" wheel of course) but your rear tire will look much fatter than the front from a profile point of view. I would go with at least a 235/35 in the front.
Old Jun 12, 2013 | 09:01 AM
terrasmak's Avatar
245/40 front and 275/40 rear is the proper size
You are much better off with 225/40 front and 245/40 rear, that would be OEM size if whad a 19 inch option like the G35 does.
Old Jun 13, 2013 | 01:29 AM
aRYip's Avatar
aRYip
[QUOTE=AdvanZ33;10146247]You may see a SLIP light under aggressive driving because your rear tire would only be a couple millimeters taller than the front.
Then how some people used square tire setup? Did they just turn off the VDC?
Old Jun 13, 2013 | 12:27 PM
neal@tirerack's Avatar
neal@tirerack
Vendor - Former Vendor
Seem a bit short actually. I would run 245/40-18 275/40-18.
What width wheels were you planning on?
Old Jun 13, 2013 | 01:29 PM
Jbakes727's Avatar
Jbakes727
lol a 9.5 and 11
Old Jun 13, 2013 | 02:41 PM
neal@tirerack
245/35-19 and 285/35-19 would work nicely.
Old Jun 13, 2013 | 03:58 PM
terrasmak's Avatar
lol a 9.5 and 11
255/35 minumum and 285/35 going agains my better judgement. I would rather not make the car handle worse that stock, but ......
Old Jun 17, 2013 | 08:58 PM
bill55's Avatar
bill55
I think you should not use this setup but if you really want to use it so as a precaution inspect it from a car care center. They will advise you well.
footballmania32
Wheels Tires
Oct 20, 2015 09:08 PM
EnjukuRacing
Coupons
Sep 9, 2015 08:13 AM
NYGiants0186
Sep 8, 2015 10:37 AM
