Varrstoen lug nuts
Old Jun 18, 2013 | 09:17 AM
ainfante21's Avatar
ainfante21
Default Varrstoen lug nuts
My Varrstoen ES2s just got delievered... without lug nuts. I was wondering what size lug nuts I need. This might be a stupid question but any time I've bought wheels they've come with lug nuts. Any help would be appreciated; pics to come!
Old Jun 18, 2013 | 09:36 AM
Deteria's Avatar
Deteria
U can use stock ones no?
I know the Z's oem wheels can use tuner style lugs or reg, as long as it's same type spec like 12.5 or w/e
Old Jun 18, 2013 | 09:50 AM
ainfante21's Avatar
ainfante21
Yeaah you can, just spoke with the wheel shop too. Thanks!
Old Jun 18, 2013 | 10:25 AM
STL 350Z's Avatar
STL 350Z
I was always under the impression you should never use oem lugs on after market wheels. You may want to do some research before mounting them.
Old Jun 18, 2013 | 11:19 AM
ainfante21's Avatar
ainfante21
The tech at the shop said the only time you can't use OEM lugs is if you're using spacers.
Old Jun 18, 2013 | 11:35 AM
X.et's Avatar
X.et
Search around and read about different lug nut shapes and the receiving wheel shapes, not all lugs and wheel setups should be combined.
Also not using oem lugs because of spacers doesn't make sense, the tech doesn't know anything - you should almost never ask advice from random shop techs unless the shop is very high quality and knowledgeable about your car and setup.
Old Jun 18, 2013 | 12:19 PM
STL 350Z's Avatar
STL 350Z
Wrong. Lug nuts don't even come into contact with the spacers. You need to get some 12x1.25 lug nuts and call it a day.
Old Jun 18, 2013 | 05:58 PM
ainfante21's Avatar
ainfante21
Thanks, I actually went to a reputable shop in the area that deals a lot with Zs and they told me to go with 12mm x 1.25 Gorilla lug nuts.
Old Jun 18, 2013 | 06:19 PM
taryon's Avatar
taryon
I'm currently running my ES3s with stock nuts, fine so far but will be changing to varrs nuts this weekend
Old Jun 18, 2013 | 09:21 PM
A-Town-Z's Avatar
A-Town-Z
I have the Varrs 12 x 1.25 open ended lugs, in neo chrome. Love them! Steel lugs, with steel threads, means happy on and off.
Old Jun 19, 2013 | 04:05 AM
ainfante21's Avatar
ainfante21
How do you like the Varrs man?
Old Jun 19, 2013 | 04:18 AM
taryon's Avatar
taryon
They're no genuines but I love em
MantisMan's Avatar
MantisMan
To be fair....some spacers that come with installed studs are longer than OEM which will need open-ended lugs. Still a pretty silly statement to make stating that ALL cars running spacers need aftermarket lugs.
The determining factors for lugs are thread size & pitch - stud length - mating surface of lugs to wheels. A little research and common sense will answer these questions pretty quickly.
Old Jun 20, 2013 | 04:44 PM
ainfante21's Avatar
ainfante21
Default Finished product
Wasn't 100% about the Matte Black, but now I'm loving them.
Old Jun 20, 2013 | 09:14 PM
taryon's Avatar
taryon
Looks good man, now you just need a drop
Old Jun 21, 2013 | 03:49 AM
ainfante21's Avatar
ainfante21
Tayron thanks , your location says New Zealand, I'm sure the roads are much nicer than they are here. I'm in the outskirts of NYC where pot holes and dips are literally EVERYWHERE. With that being said, I'm thinking about it hahaha
Old Jun 21, 2013 | 03:21 PM
taryon's Avatar
taryon
Roads here are actually pretty bad haha, it's a country basically made by volcanos and moving tectonic plates but yeah it is a pain to drive in a lowered car in crappy roads so I feel ya
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
