Cosmis Racing Wheels thread
Old Jan 28, 2016 | 05:10 AM
  #81
Nunzio762's Avatar
Nunzio762
245/40-18 on a 9.5 is nothing, it's at the upper perfectetly acceptable limits. Same with 275/40-18 on a 10.5 for the rear.
Also would the 18x 11 work for the rear with the fenders rolled?
Old Jan 28, 2016 | 06:14 AM
  #82
Pearl_Z33's Avatar
Pearl_Z33
Those offsets and tires should work fine
Old Jan 28, 2016 | 11:06 AM
  #83
terrasmak's Avatar
I believe so, it will be close. You will need a good roll and to set rear camber perfectly. I ran 18x10.5 +10 on the rear on mine with a 275/40-18 , currently I have the same setup with a 285/35-18. I plugged in the specs and here is what we have
My 285's are a lot wider than the 275/40 I ran before
Old Mar 23, 2016 | 02:23 AM
  #84
stein350z's Avatar
stein350z
... COSMIS XT206R DOESN'T CLEAR BREMBO BRAKES WITHOUT 20/25 mm SPACERS...
JUST FOR YOUR INFO...
Old Mar 23, 2016 | 04:26 AM
  #85
Pearl_Z33's Avatar
Pearl_Z33
Default Cosmis XT206R
I have a touring with normal brakes. No brembos here to worry about.
Old Oct 6, 2016 | 09:50 AM
  #86
AffyliatedZ's Avatar
AffyliatedZ
Originally Posted by cibon32
I think the wheels are 21lbs, never weighed them before mounting.
I do not have the OEM Brembos so I am not sure if they would fit over them or not.
I am running 10mm spacers all around with Extended wheel studs.
Specs without spacers: 18x9.5 +10, 18x11 +8
Tires: 255/40/18, 225/40/18
I'm running the same exact setup on my car (except I only have 10mm up front)... but my fronts look more stretched and my rears look fat compared to yours. Prob because I'm running Nittos but what gives? Lol. I'm still new at this whole "fitment" thing but seems like it's all trial and error.
Old Oct 6, 2016 | 10:34 AM
  #87
Pearl_Z33's Avatar
Pearl_Z33
Cosmis MR2s Gunmetal
Last edited by SR71; Oct 8, 2016 at 07:14 PM. Reason: No selling outside of the MP
Old Dec 10, 2016 | 10:29 AM
  #88
Infamous_Z's Avatar
Infamous_Z
Default Fitment
will 18x9.5 +10 & 18x11 +8 XT-006R clear OEM Brembos or even Akebonos? I'm on lowering springs, 1.5" drop all around running Stance camber arms and SPL eccentric lock out bolts out back.
Old Dec 10, 2016 | 04:21 PM
  #89
Bmurray350z's Avatar
Bmurray350z
Those lug nuts are atrocious
Old Dec 11, 2016 | 03:57 PM
  #90
MicVelo's Avatar
350Z/370Z Tech Moderator
Was shopping for some extended lugs on Fleabay the other day and more than half of the lugs that came up in the search were these pointy things.
Had to ask myself "Who buys those besides James Bond?"
I woulda got those but I already got this option on my car that serves the same purpose...
Old Dec 12, 2016 | 02:14 PM
  #91
CK_32's Avatar
CK_32
Ugly AF.
Hate those lugs. Usually sported by the stance and swag kids
Old Jun 10, 2017 | 10:22 AM
  #92
Nunzio762's Avatar
Nunzio762
Well finally broke down and got the wheels and I have to say I'm pretty happy with them. I didn't get the fenders rolled and so far so good. Everything fit pretty good. They do stick out a bit but I kinda like the way it looks. I do kinda wish there was a color between the gold and the bronze because they're pretty loud. Overall the car does ride better (probably because my tires were bald lol). I went with BF Goodrich g-force comp 2''s. 275/40/18 in the back and 245/40/18 for the front.
Old Feb 27, 2018 | 09:30 PM
  #93
iiLLuSiiV's Avatar
iiLLuSiiV
Default Tires
ok so i want to get the Cosmis XT-206R 18x9.5 front and for the back 18x11 but i dont know what tires to get or how much they will be can anyone throw me in the right way of tires adn what are some good ones that are not too expensive.
Old Jul 5, 2018 | 03:04 AM
  #94
Lifessimple's Avatar
Lifessimple
do you know If this applies to the xt006s? I have xt006's now and in the process of doing a brembo conversion and it doesn't clear, my current size is 18x9.5 +10 18x11 +8 , but the design of the spoke seems to be concave more than xt206 so I was hoping to run some spacers but not sure which size, thinking about getting some clean fenders to make up for the poke as well..
Old Jul 22, 2018 | 08:53 AM
  #95
NOLAGG's Avatar
NOLAGG
I would like to know as well which 18" cosmis clear or how to make them clear with akebono brakes up front .
Old Jul 22, 2018 | 07:16 PM
  #96
Lifessimple
I ended up clearing, I just installed the oem brembos yesterday, I used washers to measure the clearance I'd need for the fronts and measured at 14.3mm, bought a 15mm spacer for the front only and cleared perfectly without really much of a poke. Rears fit without modification. Running xt006r 18x9.5 +10/11 + 8
Old Jul 23, 2018 | 06:25 AM
  #97
Lifessimple
Before anyone quotes, yes the caliper is the wrong side because the bleeders are facing down, I got 2 of the same sides by accident (junk yards fault not mine) and didn't want to wait so I DID BLEED THEM right side up. =D
Old Sep 10, 2018 | 07:45 AM
  #98
ZBABE1's Avatar
ZBABE1
Default XT-006r 18x9.5 +10 Federal 595 RSRR 275/35/18 square setup on NON Brembo’s
BC DR series true coilovers. SPL front upper control arms, I can’t remember of the camber degree in the front but it’s not much. No spacer in the front and a 5mm in the rear. Front and rear fenders are rolled. Zero rub. I’ve got Brembo’s to put on but need 15mm spacer the clear the fronts. Not sure if I’ll be ok with the poke. I’ll post updated pics with the Brembo’s when I get those on. If I don’t like it, these will more than likely be for sale.
Old Nov 12, 2018 | 11:13 PM
  #99
@vq.bryce's Avatar
@vq.bryce
xt-206r's 18x9.5 (245/45) 18x11 (255/45)
Old Nov 13, 2018 | 07:08 AM
  #100
MicVelo's Avatar
Chameleon car... looks white in the "Aggressive" thread. Hahaha. ( https://my350z.com/forum/wheels-and-...l#post10976580 )
