PSA: When asking "will this rub"....
Old Feb 26, 2015 | 09:06 PM
  #61
BALDTIRES's Avatar
BALDTIRES
2006 Enthusiast with stock suspension and NO fender roll.
front: 18x8.75 +20mm 245/40/18 tire
rear: 18x9.75 +20mm 275/40/18 tire
Will it rub? Do I need to roll my rear fenders?
Old Feb 26, 2015 | 10:41 PM
  #62
terrasmak's Avatar
Offset, I have a feeling they are +20 Or +25 in XXR , either will be perfectly fine
Old Feb 27, 2015 | 01:01 PM
  #63
BALDTIRES's Avatar
BALDTIRES
Thanks Terrasmak. I did a lot of research and just wanted to make sure I didn't have a cranial-rectal inversion.
Old Mar 9, 2015 | 09:34 PM
  #64
Kharloss1's Avatar
Kharloss1
-225/35/19 F
19x8.5 +30 Offset
-Linea Corse IC818
Will tires bigger then the 225/35/19 rub in the front? I am having the problem that the current tires are too stretched and too low pro, and expose the rim and usually have them cracked, thanks to L.A potholes!...and have to pay for the weld which is not cheap. Any info on bigger wheels with more cushion and not too stretched would fit/rub would be greatly appreciated!!
Old Mar 9, 2015 | 10:21 PM
  #65
terrasmak's Avatar
Originally Posted by Kharloss1
-225/35/19 F
19x8.5 +30 Offset
-Linea Corse IC818
Answered your pm
Old Mar 12, 2015 | 12:21 PM
  #66
StuLax18's Avatar
StuLax18
General & Tech Moderator
Is it true that the RPF1s in 18 x 9.5/10.5 +15 rub? Would use 255/40 and 275/40 sized tires. Lowered on Eisnap pro-kit springs, considering coils though for that low low. I'm worried about the mounting screw for the fender liner I think it is that's close with the +23 that's on there now. I would be open to possibly adding negative camber as well as it's not driven enough right now that I'm concerned about going through tires.
Old Mar 12, 2015 | 01:39 PM
  #67
terrasmak's Avatar
Originally Posted by StuLax18
Is it true that the RPF1s in 18 x 9.5/10.5 +15 rub? Would use 255/40 and 275/40 sized tires. Lowered on Eisnap pro-kit springs, considering coils though for that low low. I'm worried about the mounting screw for the fender liner I think it is that's close with the +23 that's on there now. I would be open to possibly adding negative camber as well as it's not driven enough right now that I'm concerned about going ]
It will rub front and rear , the rear will require a simple roll to be fine. The front will need the fender liner screw cut down and folded more and maybe a hair of camber.
That's the same setup I was running when I drove to TX a while back. But I was running around -2.5 front camber for a daily and was still getting over 20k on my street tires
Old Mar 12, 2015 | 01:44 PM
  #68
travlee's Avatar
travlee
Master
he will definately need camber (almost zero'd out in fronts), and the rears are already rolled almost flat and -2.3 rear camber
(i know because this is my old car)
Old Mar 12, 2015 | 02:29 PM
  #69
StuLax18's Avatar
StuLax18
You said you didn't have the alignment sheet, or am I thinking of something else?
I'm going to look at clearance today. 8mm is about the length of my pinky nail, getting real technical with this.
Old Mar 12, 2015 | 04:17 PM
  #70
smette's Avatar
smette
2003 Enthusiast
Stock suspension and no fender roll.
front:18x9.5 +12mm 255/40/18 tire
rear:18x9.5 +12mm 275/40/18 tire
Will it rub?
Old Mar 12, 2015 | 05:20 PM
  #71
travlee's Avatar
travlee
Master
let me do some digging
Old Mar 12, 2015 | 05:23 PM
  #72
travlee's Avatar
travlee
Master
-2.1 in rear, and fronts are -.9 and -1.1
Old Mar 12, 2015 | 09:42 PM
  #73
terrasmak's Avatar
Originally Posted by smette
2003 Enthusiast
Will it rub?
The front will as mentioned above with +15 , then the rear may rub slightly at close to full compression depending where in the OEM alignment spec you fall in.
Old Mar 13, 2015 | 12:03 AM
  #74
Joel Dunn's Avatar
Joel Dunn
Will 18x9.5 +25 Square setup with 275/40/18 all around rub with stock ride height and alignment? Eventually going to lower the z about a 3/4 of an inch. Any issues... Possibly a fender roll?
Old Mar 13, 2015 | 03:30 AM
  #75
travlee's Avatar
travlee
Master
you will be okay, i ran a 9.5 +23 in rear, no roll and didnt rub when i was lowered an inch, there for a while i had a 5mm spacer and didnt rub, when i changed the +23 to a +15 i had to roll the fenders
Old Mar 13, 2015 | 09:56 AM
  #76
thatv35guy's Avatar
thatv35guy
Default 18x9 Weld RT-S Wheels on Brembo G35
I'm looking to pickup a pair of 18x9 Weld RT-S wheels, wanted some input on whether or not they'd fit my 2003 G35 Coupe w/Brembo brakes?
The pair I'm looking at are in Supra fitment, they'll be for the front only.
http://realstreetperformance.com/Whe...ront-PAIR.html
Thanks!
Old Mar 15, 2015 | 12:55 AM
  #77
sdp0101's Avatar
sdp0101
Default Plzzzz help me with offset
Ok so I'm looking to buy new rims and I slightly understand offsets but I don't want to buy them and have them not fit. I have an 04 350z touring riding stock height. Here are the rims I'm looking to buy, plz help me figure out if these will fit a stock touring Z.
http://www.nlmotoring.com/Avid-1-AV-...18855h35bz.htm
http://www.nlmotoring.com/Avid-1-AV-...18955h24bz.htm
Thx.
Old Mar 15, 2015 | 04:11 AM
  #78
Cux350z's Avatar
Cux350z
hatersgonnahate
nope...not gonna help a noob buy cheap knockoff when there is plenty of info on this forum and the internet about offsets. Did you even read the sticky?
Old Mar 15, 2015 | 04:34 AM
  #79
RUNWDVL's Avatar
RUNWDVL
Old Mar 15, 2015 | 06:43 AM
  #80
terrasmak's Avatar
9.5 +25 , it may have been done a couple times
