PSA: When asking "will this rub"....
I have 06 350Z:I want to know if thise wheels will fit my car without any issue
19x9 Front 5x114 offset 20
19x10.5 Rear 5x114.325 offset 25
Right now I didn't decided, which tires i will get until I know if this set fitting ?
Thanks guys
Thanks guys
Very common, sounds like an XXR combo
Currently running
245/40R18 front
275/35R18 rear
18x10" +20mm square
-2.4* camber front
-2.0* camber rear
Lowered on Tein Flex approx 1.25" or so.
Buying new tires soon (planning on going Hankook RS3 v2) and was thinking of doing 285/35R18 square on all four corners.
245/40R18 front
275/35R18 rear
18x10" +20mm square
-2.4* camber front
-2.0* camber rear
I would say you are good, but look up the full specs on the 275/35-18 vs the 285/35-18 RS3 , you may end up running the 275's all around.
Nitto NT555 275/40ZR18 XL front
Nitto NT555 295/45ZR18 XL rear
18x9 w/ +30 offset front
18x10 w/ +24 offset rear
Don't know the camber spec. It's all stock right now.
Stock ride height.
I'm a 350z noob, but I'm helping my dad put some wider tires and wheels on his 2005 350z touring with the Brembos.
I've been researching this for the past two hours and I've learned a lot, but I haven't found anyone with this setup with these offsets yet.
Also, if anyone has suggestions for other tires, I'm open to ideas. The Nittos were just a good price and I have really enjoyed the Nitto NT05's on my Cobalt SS Turbo, but my dad wanted something that wouldn't wear quite as fast as the NT05's.
Thanks!
Stock ride height.
Thanks!
Stock ride height.
Thanks!
Stock ride height.
Thanks!
Looking at getting new wheels and hoping someone can give me some info as to whether I will need a roll or not.
front: 19x9.5 +22 255/35/19
rear: 19x11 +25 295/30/19
Stock ride height and camber.
Fronts will be fine, rears will be close but I can't say for sure. I think you will need a mild roll to make the rears fit with no rubbing.
Alright I got a square set up of 18x9.75 with +20 offset right now with about an inch drop from camber specs -2 ish and same in the rear. Wondering what size I can fit on the front and go square tire size or staggered tires? Currently thinking of 255/40 for tires?
i currently own a 05 350z. Its still stock height for now because i dont want to lower it yet until i purchased wheels. I purchased a set of 18x10.5 wheels with a +15 offset all around. Ive had the wheels for 1 week now and i am contemplated on what size tires i need to go with so i dont rub at all in the front or the back. Please and thank you for who ever can help!
fr 265/35/18 on 9.5+15
rr 295/35/18 on 10.5 +15
No worries at stock height. gl
Could I do 265/35/18 on 10.5 wheels? I have 10.5 all around and I was planning to do 265/35/18 all around as well. Will this rub at all? I'm stock height and +15 offset.
Front may, just depends on the actual tire, not all 265's are actually the same width. The rear is just really short and shouldn't rub
so planning to shop for new set up
I got 07 350z touring
j m thinking Enkei RPF1 18x10.5 +15 with
Hankook ventus v12 285/35/18 all around
I m on stock suspension/height/camber right now
eventually gonna put BC racing BR coilover.
will it have any issue if I put set up like that as right now with stock height
also question about any VDC issue if I put square set up like that
just curious since I daily my z
and should I put coilover first before put new wheels?
also I saw some ppl put square set up like this and put 15mm spacer in rear..?why???
thnks for advices
thnks for advices
