Trying to decide which rims to pick
Old Oct 7, 2013 | 08:12 AM
garrettxJDM's Avatar
garrettxJDM
Default Trying to decide which rims to pick
Hey I'm doing wheel inventory for work and I can get a set of rims for my car through work. These are the ones I've found that I like was just wondering which style, and color you think would work/ look better. My z's the le mans sunset.
Motegi Racing MR122 in black are 18x8 front; backspacing 5.87", 18x9 rear back spacing 6.38" . Off set 35mm.
Motegi Racing MR125 in black or grey are 18x8 front; backspacing 5.79", 18x9 rear; backspacing 6.30". Off set 35mm
Motegi Racing MR120 in black or silver are 18x8.5 front; backspacing 5.98", 18x9.5 rear; backspacing 6.50". Off set 32mm
Attached Thumbnails Trying to decide which rims to pick-motegir_mr120-black.jpg   Trying to decide which rims to pick-motegir_mr120-sliver.jpg   Trying to decide which rims to pick-motegir_mr122_bml_ci3_l.jpg   Trying to decide which rims to pick-motegir_mr1255-black.jpg   Trying to decide which rims to pick-motegir_mr1255l-matte-grey.jpg
Old Oct 7, 2013 | 08:28 AM
travlee's Avatar
travlee
Master
try to find something with a better offset, most get a +15. the tire is wider than factory but the offsets are also around factory so the wheel will be sunk in
Old Oct 7, 2013 | 08:37 AM
garrettxJDM
Could I fix that with wheel spacers if I cant find a wheel with that offset?
Old Oct 7, 2013 | 08:44 AM
travlee's Avatar
travlee
Master
you could but it would be best to get the correct offset
Old Oct 7, 2013 | 08:48 AM
garrettxJDM
I figured as much, I can't find a wheel with that offset that I like. I'll try searching through wheels with out it having my car as the search option and see what else I can find with the right bolt pattern.
Old Oct 7, 2013 | 08:51 AM
terrasmak's Avatar
Since you have JDM in your user name, look at wheels made in Japan.
Nothing less that 9 inch front and 10 inch wide rears
Old Oct 7, 2013 | 08:57 AM
garrettxJDM
The 370z have the same wheel specs/ hub diameter as the 350's don't they?
Old Oct 7, 2013 | 08:59 AM
ZS14RR's Avatar
ZS14RR
None of those ugly chits you posted.
Old Oct 7, 2013 | 09:00 AM
pss350z's Avatar
pss350z
Are we gong for a 5th gear chirp??
Old Oct 7, 2013 | 09:02 AM
ZROCM's Avatar
ZROCM
I'm running 8.5 front with a +25 offset with 245/40-18 tires and on the rear 9.5 with a +22 offset with 275/40-18 tires.
Old Oct 7, 2013 | 09:06 AM
travlee's Avatar
travlee
Master
this is the same setup i am running... i am content with it
Old Oct 7, 2013 | 09:08 AM
travlee's Avatar
travlee
Master
he asked a legitimate question this time, i was soooo confused about offsets when i was looking for them also
Old Oct 7, 2013 | 09:17 AM
garrettxJDM
Alright. Here's the thing though. At work I can get select tires for free as long as we get them into our facility. The biggest tire we get in is a 18x9 or 18x9.5 I can't remember off the top of my head. And the company I work for goes through tirerack for wheels for us to use for testing. So if I want free wheels I have to go through tirerack and add them to the rim order list. And I can't make them too expensive or the company won't buy them lol. I'm just looking at getting a set that I like, and can ride with for a while till I save up enough to get something better. I just want to get rid of the stockers, and I can't pass up a opportunity for free rims.
Old Oct 7, 2013 | 09:18 AM
garrettxJDM
Yeah I know tires, but not much to do with rims at all. There's a lot of stuff to figure out to see if a rim will fit.
Old Oct 7, 2013 | 10:20 AM
garrettxJDM
There's a guy at work that knows a lot about rims that I'm friends with. I'm going to have him help me do some measuring and calculating on these offsets so I can see what'll look like. Biggest thing for me is as long as they're out farther than the stockers i'll be happy. And I'll throw on some spacers to move them out more. Until I get the money to actually buy a really nice set of rims for it.
Old Oct 7, 2013 | 10:50 AM
travlee's Avatar
travlee
Master
i wouldnt go any more than like a +27 and then throw some 10mm spacers...
Old Oct 7, 2013 | 10:53 AM
garrettxJDM
I'll keep that in mind! thank you!
Old Oct 7, 2013 | 11:06 AM
pyshin's Avatar
pyshin
If 18x9.5 is the largest you can get, then you should get that size square (all 4) with the lowest offset possible. Then buy HUBCENTRIC wheel spacers to bring the offset around ~+15 up front (maybe go a bit wider spacer in the rear to bring offset ~+5 since most run 9.5 front/10.5 rear). That should work well until you have the funds to purchase true low offset quality wheels.
Yes, all of those wheels are hideous. But if that's your choice, it's your choice. Honestly I see that Tire Rack sells Enkei (which is a great brand)... is the price too high to order on one of the lists..?
Old Oct 7, 2013 | 11:25 AM
BY350z's Avatar
BY350z
If your place of work gets wheels through tirerack why not get some enkei rpf1's instead? They're very light and strong better than those anchor weights u posted. I recommend them in 18x10.5 + 15 all round with 265/35/18 tires
Old Oct 7, 2013 | 11:42 AM
garrettxJDM
Yeah I know they're not the best but look better than stockers imo. And yeah I was looking at Enkeis, but I believe it would be pushing it; and more than likely wouldn't be able to get them. That's why I settled around these. However when we go to actually send in the lists tirerack may have a different selection by then with something better and around the price range I'd be able to get! Hopefully..
