Another "will this rub" thread
Old Feb 21, 2014 | 04:06 AM
mnd7775's Avatar
mnd7775
Default Another "will this rub" thread
Hi all, didn't see an appropriate thread so move if needed. The question is will this rub/fit without any issues:
Enkei Raijin
18X8.5 +35mm (F) 245-40-18
18X9.5 +15mm (R) 265-40-18
Car is stock height and no camber mods. I would like to stay away from rolling the fender, but would be open to a spacer in the rear. Also open to any tire size suggestions.
Thanks
Old Feb 21, 2014 | 05:34 AM
travlee's Avatar
travlee
Master
no it will not rub.... this has been asked a million times though
Old Feb 21, 2014 | 05:44 AM
taryon's Avatar
taryon
It will fit with no rubbing issues however I would recommend getting wider wheels (eg 9.5F 10.5R) with lower offset (which may require rolling fenders). Your fronts would be a bit sunk in with those specs
Why are you staying away from rolling fenders? It's quite simple and useful!
Old Feb 21, 2014 | 06:09 AM
mnd7775's Avatar
mnd7775
I really like the look and the price of these wheels, and 9.5 is the widest they go in 18". Rolling of the fenders just seems like a waste of money and effort to me if I can just get a set up that fits out of the box. Will the size of these tires fit fine on the wheels?
Old Feb 21, 2014 | 07:03 AM
terrasmak's Avatar
At least get 9.5 front and rear
Old Feb 21, 2014 | 11:06 AM
JMS71585's Avatar
JMS71585
Add on 25mm spacer in the front and a 5mm spacer in the rear. That will give you a flush look with your fender in both the front and rear. At stock height, there will be no rubbing issues. Once you lower the vehicle beyond 0.75", you may have watch for rubbing issues.
Tochigi_236
Sep 27, 2015 03:40 PM
