18" wheels to fit StopTech BBK
Old Mar 5, 2014 | 08:16 AM
XM 1's Avatar
Default 18" wheels to fit StopTech BBK
if been looking for some 18" wheels for my car for the winter time (to basicly have them on the car all winter long while it sits in the garage). these have to clear the StopTech 6 pot 4pot BBK. i'm looking for something sporty like the Enkei RPF1. they should have 8.5 up front and 9 or 9.5 in the rear. or does anyone know the offsets for these Enkei rims? oh btw i really don't want to run spacers to make them fit!!
Old Mar 5, 2014 | 08:18 AM
travlee's Avatar
travlee
Master
do a 9.5 +15 on all corners and you should be okay.
Old Mar 5, 2014 | 09:11 AM
XM 1's Avatar
well that's pretty aggresive up front i have the 9.5 +17 VOLK GT-S up front and wanted something more subtle for the winter time
Old Mar 5, 2014 | 09:20 AM
07maximan's Avatar
07maximan
+15 isnt that aggressive. I run +12 and I have no issues at all.
Old Mar 5, 2014 | 09:37 AM
travlee's Avatar
travlee
Master
depends on the look he wants and likes, we all have diff tastes.
Old Mar 5, 2014 | 10:00 AM
XM 1's Avatar
just checked the offset specs available for those RPF1...it really seems like there is only the 9.5 +15 suitable for the Z......i'm more afraif about the caliper clearance since those 6 pot StopTech calipers really need a lot of clearance!!
Old Mar 5, 2014 | 10:39 AM
Waiz's Avatar
Waiz
What StopTech BBK are you referring to OP?
As you know it all depends on the wheel style, disc size (if applicable), and offset
If you are trying to run the RPF1's that is one of the easiest wheels to fit the StopTech's with and depending on what BBK you have I can give you a recommendation
Old Mar 5, 2014 | 09:55 PM
XM 1's Avatar
i have the 14" BBK kit with the (i guess that's what they are called) ST60 and ST40 calipers
Old Mar 6, 2014 | 04:23 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
ST60 on the front actually clears wheels easier than the ST40
Enkei RPF1 front 9.5 + 15 and rear 10.5 +15 would be perfect. Run 275 and 295 tires which is bad in the snow though.
Old Mar 6, 2014 | 05:45 AM
XM 1's Avatar
Cux350Z it's not for the snow :P it's basicly for storage of the car! don't want to let the car sit on the expensive tires and wheels.....but still want to use the RPF1 in the spring time and then switch over to my GT-S. but if the 10.5 +15 clear the ST40 these would be good too (i guess)
Old Mar 6, 2014 | 06:50 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
on the rear yes. That is what I have been told. I am in your same shoes in wanting a different wheel setup and I love the RPF1's. My rear GT-S barely clears.
Ok then tire widths be damned! run wide and be happy.
Old Mar 7, 2014 | 12:39 AM
XM 1's Avatar
Yeah the GT-S are a pretty tight fit on the rear will prob. get a set of RPF1 or maybe the new Work CR Kai Kiwami...let's see
Old Mar 7, 2014 | 10:32 AM
Waiz's Avatar
Waiz
Btw, StopTech provides templates to make certain you can fit your wheels
http://www.stoptech.com/technical-su...ment-templates
Old Mar 11, 2014 | 07:47 AM
XM 1's Avatar
yeah i know Waizzz the problem here is that we don't have any japanese wheels around here in germany...at least not stocked
Old Mar 11, 2014 | 10:10 AM
Waiz's Avatar
Waiz
Well we can always have someone print it out for you who owns a set in that same size
Old Mar 11, 2014 | 10:32 PM
XM 1's Avatar
that would be nice
