Question about tires..
Old Feb 2, 2004 | 10:43 AM
infidsg35's Avatar
infidsg35
Default Question about tires..
Im looking to get some S-03's.. Do I have to change all the tires? Im going to get the 255/40/18 for the rear. Do I have to change the front or should I keep it the same? (225/40/18) or should I go a lil bigger?
For those who dont know OEM tires for a G is 225/45/18 front and 245/45/18 for the rear.
Old Feb 2, 2004 | 10:50 AM
Audito350Z's Avatar
Audito350Z
I did 245/40-18 front and 244/40-18 rear... on the Z that sizing keeps the front to rear proportions close the OEM proportions.
I would have thought the G35c has the same 18" size tires as the Z??? That would be 225/45-18 front and 245/45-18 rear.
Old Feb 2, 2004 | 12:03 PM
infidsg35's Avatar
infidsg35
Ha Ha you cought me. You saw it before I could change it LOL.. I think im going to stay with the 225 for the front as wider wont realy help much in that area.. What is the lowest sidewall number? 35? Cause I wanted to get something a lil bigger then 255.. At least 265 which I was told that the stock rim could handle.. Any ideas?
Old Feb 2, 2004 | 12:08 PM
Moroccan_Mole's Avatar
Moroccan_Mole
you can't fit 265's on the stock wheels.
Old Feb 2, 2004 | 02:42 PM
infidsg35's Avatar
infidsg35
are u sure??
Old Feb 2, 2004 | 03:09 PM
1nate7's Avatar
1nate7
You could go as wide as a 275/40 if you really wanted to. However, this is not recommended with the 8" wide wheels. IMO its somewhat of a safety concern and it wouldn't look right either with all that tire bulge. There was a big debate about this a month ago in the g35 forum. I personally just ordered 245/40 and 255/45 - wider rubber, overall diameters are close (exact for the front), and eliminates some understeer.
Unless different tire brand/treads bother you, you could keep the fronts as they probably have plenty of tread left. I would go with 255/45 (closer to overall stock diameter) or 255/40 for the rear.
Old Feb 2, 2004 | 06:17 PM
lowrider's Avatar
lowrider
1nate7 gives good advice. Listen to him, except I would not put 255/40s on the back, too low. 255/45s are fine though.
Lou
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
