Will it rub and will vdc be affected
Old May 29, 2016 | 09:45 PM
Mitchbuck21's Avatar
Mitchbuck21
Default Will it rub and will vdc be affected
I ordered a set of 18x9 +20 fronts that I'm planning on running a 245/35 tire on and rear 18x10.5 +22 rears that I would like to run a 285/35 on. I do not want to roll or rub and I'm at stock ride height on an 04 touring. Feedback would be great thanks
Old May 30, 2016 | 12:27 PM
Spike100's Avatar
Spike100
You should be fine. I doubt you will rub at stock height. In fact you can probably drop less than 1 inch and be OK.
Old May 31, 2016 | 06:43 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
Widths aren't the issue here. Height is. Way too low.
225 45% 18 25.97 Stock reference size F
245 45% 18 26.68 Stock reference size R
245 40% 18 25.72
245 35% 18 24.75
255 35% 18 25.03
255 40% 18 26.03
255 45% 18 27.04
265 35% 18 25.30
265 40% 18 26.35
275 35% 18 25.58
275 40% 18 26.66
285 30% 18 24.73
285 35% 18 25.85
285 40% 18 26.98
295 30% 18 24.97
295 35% 18 26.13
295 40% 18 27.29
305 35% 18 26.41
305 40% 18 27.61
Picked up a set of 10.5 +25 rears once with tires on 'em. Guy had put 295/35s on them that fit fine - lowered - but still too short.
Old May 31, 2016 | 07:49 AM
Mitchbuck21
245 40% 18 25.72
245 35% 18 24.75
255 35% 18 25.03
255 40% 18 26.03
255 45% 18 27.04
265 35% 18 25.30
265 40% 18 26.35
275 35% 18 25.58
275 40% 18 26.66
285 30% 18 24.73
285 35% 18 25.85
285 40% 18 26.98
295 30% 18 24.97
295 35% 18 26.13
295 40% 18 27.29
305 35% 18 26.41
305 40% 18 27.61
So 245 40 fronts and 275 40 rear would be better your saying?
Old May 31, 2016 | 04:04 PM
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
Yes thats what he is saying... 255/40/18 front 275/40/18 rear keeps everything happy... You could do 245/40 front also as an option...
35 series tires would look horrible and handle like the poopoo.. It would look like a z 4x4 baja
Old May 31, 2016 | 04:09 PM
terrasmak's Avatar
255 or 245/40-18 front with 275/40-18 rear and your golden
Aug 7, 2016 11:34 PM
ukraini9mofo
May 16, 2016 09:56 AM
2000atlanticgt
Wheels Tires
May 12, 2016 03:01 AM
Gabriellajergos
May 2, 2016 07:06 PM
NFAC
May 1, 2016 05:01 PM
