tire size help
Old Sep 7, 2016 | 03:36 PM
nizmo_0385's Avatar
nizmo_0385
Default tire size help
hello all stuck on tires sizes with a particular brand.
Front Wheel is 19x10 options are 255 35 and 265 35
rear wheel is 19x11 option 275 35 or 285 30
30 series scares me wish it was a 35 but It isnt.
what shoukd I do
Old Sep 7, 2016 | 03:38 PM
nizmo_0385's Avatar
nizmo_0385
what shoukd I do
edit 295 30 isn't option either
Old Sep 7, 2016 | 04:09 PM
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
265/30 front 285/30 rear my vote...
Old Sep 7, 2016 | 04:37 PM
nizmo_0385's Avatar
nizmo_0385
ok thanks . am I over thinking the 30 sidewall. I'm afraid of rubber band tires...
Old Sep 7, 2016 | 05:48 PM
jhc's Avatar
jhc
General & Tech Moderator
I'm on 18's, +12 x4.
9.5=265/35
10.5=295/35
Lowered 1" on Eibach Pros. For me, it's a nice fit. And when I pass those traffic signs with a built-in radar, my speed is within 2-3 mph. (My speedo is higher).
All depends on what you want. Obviously handling improves a bit with a shorter tire and ride cush suffers. I like a little more rubber than wheel. Scarred for life when I let my old boss drive my Mitsu and rashed a BBS.
Ck the Wheels/Tires threds for ideas!
Old Sep 7, 2016 | 05:51 PM
dboyzalter's Avatar
dboyzalter
I think it's your only choice unless you want a lift kit... 265/35 is what would work on an 18inch wheel for a front tire.
255/35 front and 275/35 rear would work well also but its going to be stretched on those wide baller wheels.
Old Sep 7, 2016 | 05:57 PM
dboyzalter's Avatar
dboyzalter
I have a 245/40/18 on a 9.5 wheel so I 255 on 10 inch would probably have a similar stretch, if you wanna call it that.
Old Sep 7, 2016 | 06:01 PM
dboyzalter's Avatar
dboyzalter
If 295 is an option go with that... 265/30 295/30
I kinda wish I would have gotten 265s in front
Old Sep 7, 2016 | 06:42 PM
nizmo_0385's Avatar
nizmo_0385
went with a different brand bfgoodrich
front 265 35 19 which is very close to my oem front 245 40 18
and rear went with 285 35 19
thanks guys for the help. the added sidewall will help me protect my volk re30!
Old Sep 7, 2016 | 06:48 PM
jhc's Avatar
jhc
Good call! Post pics Chris.
Old Sep 7, 2016 | 08:01 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
what shoukd I do
225 45% 18 25.97 Stock Reference Size
245 45% 18 26.68 Stock Reference Size
235 40% 19 26.40
235 35% 19
245 45% 19 27.68
245 40% 19 26.72
245 35% 19 25.75
255 40% 19 27.03
255 35% 19 26.03 Front-Alternate
265 35% 19 26.30 You can get away with this up FRONT so long as you "match upwards" the rear tires to keep VDC/TCS happy.
265 30% 19 25.26
275 40% 19 27.66
275 35% 19 26.58 Rear-Alternate
275 30% 19 25.50
285 40% 19 27.98
285 35% 19 26.85 This will match the 265 well as its a bit taller than stock.
285 30% 19 25.73
295 35% 19 27.13 If you want a little extra, these will fit and height isn't terribly tall.
295 30% 19 25.97
305 35% 19 27.41
305 30% 19 26.20
315 35% 19 27.68
315 30% 19 26.44
But as always, will they physically fit?
Height wise, NP. Width wise, I'd be a slightly concerned on your Nismo, Chris, since it's lowered a fair amount as I recall. Standard warnings apply.... rolled rears might be the ticket.
Fit on wheel:
10" wheel can take any tire from 235 to 305 reasonably (90% to 120% of wheel width although it's better to go > 1:1) and 11" wheel 255 to 335mm before you start to see performance drop off.
Other caveat: availability of tires in matched sets. Go on TR and check that 265/295 combo..... not much choice at reasonable pricing.
Go 255/285 and it's a whole different ballgame.
Good luck..... whatchu gonna be running THIS time?
Old Sep 7, 2016 | 08:59 PM
nizmo_0385's Avatar
nizmo_0385
thanks alot mic that helps tons.
rears are rolled
front fender screw removed.
went back to lowering springs. eibach sportline. have rear camber arms and spc toe bolts.
wheels are volk re30 formula Silver gtr specs
19x10 +30
19×11 +20
will definitely post pics.
thanks all much appreciated!
Old Sep 8, 2016 | 03:58 AM
MicVelo's Avatar
Oh jeesh, hadn't seen that you went with the BFGs and what whills you got before posting response. Doy.... Oh well, at least what I said corroborates your decision. < where's that pat-myself-on-the-back emoji at? >
Sounds great, Chris!
Old Sep 10, 2016 | 12:57 PM
nizmo_0385's Avatar
nizmo_0385
welp. plans changed again. in order to save some money I bought a friend's new rear tires 295 30 toyo proxes 1.
now in order to keep vdc and traction and all that happy what sizes will be best front.
rear is 11inch front is 10 inch
im leaning 265 30 or 275 30 19?
Old Sep 10, 2016 | 06:36 PM
MicVelo's Avatar
255/35-19 at 26.03 O.D. still works just fine since the 295/30 is the EXACT same O.D. as OEM 245/45-18.
mkp0203
May 26, 2017 10:00 AM
7rrivera7
Tuning
Sep 27, 2016 04:51 PM
ZSAREBEL
Sep 7, 2016 03:06 PM
nizmo_0385
Wheels Tires
Sep 6, 2016 09:25 AM
sjtomcat
Sep 4, 2016 01:47 PM
