Rim Question, Will They Fit??
I have the chance to pick up a mint set of rims in Black Chrome, but I am unsure if they will fit. Here it is:
Front- 18x9 +24mm offset
Rear- 18x10 +22mm offset
5x4.5 (114.3) lug pattern.
They were bought for a mustang but never put on and are brand new.
I also have the Eibach drop installed on my car and I am worried that the offsetts may be to much and I will bottom out on the fender. Let me know what you guys think..
those rear wheels might stick out a few millimeters past the fender...
and, you will need the correct hub centering ring to change the hub opening in the wheel to fit on your Z's hub... Discount Tire can help you with that, but you will need to know the size of the hub opening in the wheel.
Hope that helps,
PeteH
Hope that helps,
PeteH
the hub thing is no big deal. its common, most all rims are made to fit the larger hub size since you can go smaller but not bigger.
they should fit... Id be a bit worried about the back rubbing. probably depend how wide of a tire you put on. 275 would be ok IMO, 285 or 295 might not.
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
