How much camber to not rub?
So fender rolling isn't an option for me. The fenders are already showing signs of cracking on the paint. I'll eventually cut them and add over fenders. buut, for now, how much camber will I need to clear them?
Stock suspension
19x11" +22 wheels with 285/35 tires.
Thanks. If you have camber to clear let me know what you needed to make it work.
Stock suspension
350Z/370Z Tech Moderator
Ow. I just bit my tongue so hard it's bleeding.
I'll say it as calmly as I can.
CAMBER IS NOT FOR TIRE FIT!!
And besides, if you have STOCK SUSPENSION, how do you propose to minus the camber??
But if you wanna do it.... your car, your handling, your safety.
ok. sorry, forgot to mention I'd buy camber arms of course.
If I only have to run an extra -1' of camber idk why you act like it'd be so bad...
But screw it,ill roll them and touch up if it cracks more.
if you dont feel comfortable rolling them, hit up Acid Jake on here. he is in Carrolton and used to work on my Z, and rolled my fenders for me
Or at the least, end up cursing the handling of your car when it refuses to turn in like it did stock. Again, your call.
So on that note, can't vouch for an 11" wheel but a 10.5 +22 with the 285s works fine at lower limit of alignment range WITH fender roll, which, IMO, is a better way to go than to mess with the handling.
well I got a lot rolled with my grandpa last night using some DIY stuff.
Worked pretty good, not perfect, but the rub is down to minimal only in terrible situations.
Hopefully a little more love will clear it up all the way.
thanks
thanks
