tire size for 18x11?
Old Dec 17, 2019 | 05:19 AM
Blackskiies's Avatar
Blackskiies
Exclamation tire size for 18x11?
Im wondering if 275/40-18 will fit an 11 wide rim, and if theres pictures please link
This is the website i hv been using to reference but idk...:
https://www.tyresizecalculator.com/c...rim-size-chart
Old Dec 17, 2019 | 05:35 AM
travlee's Avatar
travlee
Master
If you want the dumb stretch look
Old Dec 17, 2019 | 05:38 AM
Blackskiies
even with a higher profile of 40?
Old Dec 17, 2019 | 07:23 AM
Mully's Avatar
Mully
I run 285/35-18 Falkens on a 10.5" wide wheel. The tire sits completely flush with the wheel - zero stretch, zero bulge. If I wanted to run a 0.5" (~12mm) wider wheel I'd run a 295 (10mm wider) to get similar fitment, though I'd personally go to 305+ because I loathe stretched tires. As Trav mentioned, expect some stretch running a 275 on an 11" wide wheel, regardless of aspect ratio.
Pic of my set up for reference:
Old Dec 17, 2019 | 07:27 AM
Dr Hoon's Avatar
Dr Hoon
5 Year Member
275mm is equivalent to 10.8 inches, which is damn close to the width of the rim. Unfortunately that's the measurement of the widest part of the tire sidewall, not the thread, so depending on the manufacturer and model the actual thread might be a lot narrower. Discount brand tires are known for using narrower threads to save on manufacturing costs. Check tirerack or other reputable outlets that list the actual thread width before you buy, find a brand/model with nice wide thread and it'll fit just fine.
Old Dec 17, 2019 | 07:45 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
All of the above. ^^^
275 will "fit"; but general rule of thumb is to run a tire tread width AT LEAST equal to width of the wheel. As noted, some tires are wider and some narrower than "advertised". The best performance comes from a tire that is 100-120% of the wheel width so the above recommendations from Mully and DocHoon make a lot of sense. Below 100% and above 120% will both "fit" but performance at the limit falls off above and below that range.
That all said, however, a 275 is a decent fitment being so close to the theoretical "ideal" tire size, particularly due to tire availability/cost. Also, going much over that may necessitate fender rolling in the rear - depends on the wheel offset.
Old Dec 17, 2019 | 08:18 AM
terrasmak's Avatar
m will fit without issue . Run it' it may/will be slightly stretched but not close to unsafe levels.
armt350z
Dec 30, 2015 09:53 AM
dreamspeed
Feb 5, 2015 03:43 PM
Germanguy
Apr 6, 2009 10:31 AM
jasinc19
Feb 25, 2006 10:12 AM
