Tire size for 19x9.5+22 , 19x10.5 +22?
If someone with some knowledge of wheels/tires can chime in, it would be greatly appreciated. I need some help choosing tires. The tires in question are ToyoR888R's. Using the TireCalc here's the data for some of the tire sizes available for my wheels 19x9.5+22 , 19x10.5 +22. Side note my front fenders are +12mm wider and the rear fenders have been pulled and rolled.
Front Tire:
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
225/45-18 4.0in 13.0in 26.0in 81.6in 777 0.0%
265/30-19 3.1in 12.6in 25.3in 79.4in 798 -2.7%
265/35-19 3.7in 13.2in 26.3in 82.6in 767 1.3%
275/30-19 3.2in 12.7in 25.5in 80.1in 791 -1.8%
Rear Tire:
245/45-18 4.3in 13.3in 26.7in 83.8in 756 0.0%
285/35-19 3.9in 13.4in 26.9in 84.4in 751 0.6%
295/30-19 3.5in 13.0in 26.0in 81.6in 777 -2.7%
305/30-19 3.6in 13.1in 26.2in 82.3in 770 -1.8%
I see that quite a few people run 265/30/19 F, 295/30/19 R but I see that there is a 2.7% difference. Would running 265/35/19, 285/35/19 be better? or perhaps 265/35/19, 295/35/19? Or does it not matter as long as the difference is within the 3% threshold for VDC?
-E
Front Tire:
Rear Tire:
-E
350Z/370Z Tech Moderator
Front Tire:
Rear Tire:
295/35-19 4.1in 13.6in 27.1in 85.2in 743 1.7%
-E
Front Tire:
Rear Tire:
-E
F: 245/35-19
R: 275/35-19
Or go up to 255/285. These sizes all maintain the correct ~3% ratio. If you opt for 30 aspect, make sure you do both front and rear in similar sizes to keep the F-R delta correct - 3.0% +/- ~.0.3% (~2.7% is OE)
Soundeffects
Jul 16, 2006 11:22 PM
