paint the wheel? how much?
Old Mar 3, 2004 | 12:10 PM
wutafobb's Avatar
wutafobb
Default paint the wheel? how much?
anyone have done this?
how much does it cost to paint my wheel to match my silverstone?
thx
[IMG]
Old Mar 3, 2004 | 12:30 PM
Audito350Z's Avatar
Audito350Z
figure about $20 - $50 per wheel to remove the current finish, usually sandblasting off the original coating
then figure anywhere from $50 - $200 per wheel to paint, mostly depending on the paint you choose and who does it
Old Mar 3, 2004 | 08:04 PM
mgl's Avatar
mgl
powdercoating my first set of 19s cost $350.
Old Mar 3, 2004 | 08:29 PM
ares's Avatar
ares
Veteran
powder coat dont paint. paint chips too easily(as youve no doubt noticed on the rest of the car)
then have a clear coat paint put over the powder coat so you can wash and was the rims. its the same process thats on the rims now, and on most all aftermarket rims.
Old Mar 4, 2004 | 01:21 AM
wutafobb's Avatar
wutafobb
whats the difference powder coat and paint? and where should i go to have powder coat done..just normal body shops?
Old Mar 4, 2004 | 07:10 PM
mgl's Avatar
mgl
not a body shop... but a powdercoating shop
Old Mar 4, 2004 | 08:36 PM
Strife350z's Avatar
Strife350z
Painting is just spraying on a new layer of paint on top of your wheels. If your wheels are sanded down and primed properly, and then multiple layers of clearcoat put on top of it, you probably won't have any paint chipping issues for a few years... or the first big rock that gets lodged in your spokes... whichever comes first
Powdercoating is a lot more robust. The shop will positively charge your rims on the spots where you need the coat applied. This usually involves spraying on a layer of positively charged primer. Then a fine layer of negatively charged powder/resin gets sprayed over the positively charged areas of your rims... which causes the powder to bond with the positively charged primer. This is what adds color. Your wheel will then be baked in a kiln to allow the powder/resin to cure. The result is a non-brittle, durable finish.
As a side note, that's why you can't powdercoat plastic... it melts in the kiln :P
Obadabot
Jun 18, 2023 11:31 PM
