19" X 9.5 +12 offset
Old Mar 3, 2004 | 05:46 PM
pkc415's Avatar
pkc415
Default 19" X 9.5 +12 offset
Anyone have 19X9.5 +12 offset in the front? If so, please post pictures. Thanks.
Old Mar 3, 2004 | 06:11 PM
ranger5oh's Avatar
ranger5oh
Offsets are kinda different per wheel manufacturer. Any in particular you wanna see? A +12 on one wheel might be like a +20 on a different wheel... they dont all fit exactly the same.
Old Mar 4, 2004 | 07:30 AM
Audito350Z's Avatar
Audito350Z
actually, offset is the same no matter what wheel... a +12 is always a +12... it means the centerline of the wheel is 12mm away from the back surface of the mounting hub of the wheel. You can have negative, positive and zero offsets. See the link below for info at Tirerack's site.
More info here http://www.tirerack.com/wheels/tech/offset.htm
A +12 offset will sink the wheel into the wheel well too far and most likely rub on the inside suspension components. A -12 offset will push the wheel way out from the side of the car, likely causing it to rub on the fender.
PeteH
Old Mar 4, 2004 | 08:48 AM
pkc415's Avatar
pkc415
I wanna see Volks in these offsets.
tkuntz
Wheels Tires
Oct 3, 2015 05:58 PM
