Unofficial Rim Size/Offset Thread
Old May 26, 2004 | 02:05 AM
  #41
zillinois's Avatar
zillinois
9.5 +12 has been done before and looks great. That's a very radical offset compared to your front. You are gaining 1-5/16" out toward the fender in the rear, but only 1/4" up front. I think it will look fine, its just that your back wheels are going to be flush with the wheel well and your fronts will look a little recessed.
7mm is just over 1/4". So, no it won't look that noticeable. If you haven't ordered them yet, the +22 might be the way to go up front.
Old Jun 21, 2004 | 04:13 PM
  #42
zillinois's Avatar
zillinois
Ok, thanks to Zquicksilver I have a correction to make. The 9.5/19" and 38mm offset should be changed to a Stock+ of 7/16" instead of 5/16". (1/8" off, my bad.) The distance from hub is also increased to 3-3/8". Sorry for the error.
Old Jun 22, 2004 | 12:08 PM
  #43
Zquicksilver's Avatar
Zquicksilver
zillinois,
Thanks for making the correction. To bad were not allowed to edit our original posts...???
I just want to say my hat is off to "zillinois " for doing an outstanding job of compiling data on wheels and their offsets that is both informative and helpful when trying to decide on a pair of rims. The pictures say a thousand words compared to the data. Sometimes one can only imagine what his or her rims might look like on their Z, but with the aid of this thread the guess work is removed.
Thanks zillinois, we all appreciate it .
Ps if you have questions about a certain size wheel and offset that is not provided by zillinois chart this webpage may help you. You just plug in the necessary data and it gives you new reference points in comparison to your old wheels.
http://www.mindspring.com/~toy4two/offset.html
Old Jun 22, 2004 | 12:32 PM
  #44
Road Warrior's Avatar
Road Warrior
can anyone give me the specifics on this setup pics
i think this is the perfect setup for 19's...need sizes and offsets for rims
i believe the rear is 9.5 +35....
gonna go with the volk sf winnings so this is very close to what mine will look like...thanks all
Old Jun 22, 2004 | 12:48 PM
  #45
Zquicksilver
road warrior,
if this is what your asking...?
those are ADR rims...8.5f +35 and 9.5r +35. they do look nice...
the perfect VOLK SF set up is 8.5f +25 and 9.5r +29.
this is what two different volks specialist told me...no mods at all
Old Jun 22, 2004 | 01:04 PM
  #46
Road Warrior
zquicksilver,
thanks bro....i know they are two different brands so they are probably going to be different in offsets...but ya, as long as the end result is the same sounds good....really appreciate the info
so have you decided yet? best to take your time and get exactly what you want....i know you have been at it a while now...good luck with your decision....and again, thanks
Old Jun 22, 2004 | 01:33 PM
  #47
tekneq's Avatar
tekneq
I have a set of 19by8.5 with 40 offset that i took off my maxima....they have 235/35/19's on them will this work?
Old Jun 22, 2004 | 02:58 PM
  #48
Zquicksilver
road warrior,
i'm still undecided as to which rims to go with...but i'm going to choose soon. i want to install them sometime in july, so i will most likely order them this monday, just thinking a little bit as to which will make me the happiest...
9.5s at +30,+35,+38 are all ok looking. not to tucked or sticking out past the fenders.
here are some pics to verify things...
Attached Thumbnails Unofficial Rim Size/Offset Thread-offsets.jpg
ablaine
Nov 29, 2016 10:13 AM
