Touring model tire psi
Old Apr 12, 2004 | 07:23 AM
350Chas's Avatar
350Chas
Question Touring model tire psi
What do you guys run as tire pressure on your touring model?
The max psi on the stock tires is 51, i know it says a tire running low in my info center at under 33psi.
So somewhere in between?
I pumped up to 45psi since its getting warmer out.
Just curious what you guys run.
Old Apr 12, 2004 | 09:18 AM
bixby's Avatar
bixby
Default Re: Touring model tire psi
45? Holy cow! That seems a bit high to me. I run mine at 35, which is what is recommended per the owners manual.
Old Apr 12, 2004 | 10:05 AM
SungNamZ's Avatar
SungNamZ
Recommended tire pressure is on the plate on your door plate. Keep them at 35 psi "cold" unless you are planning on doing things at the track.
Old Apr 12, 2004 | 10:51 AM
isugoo's Avatar
isugoo
45psi????
are you trying to make your tires like pamela anderson's tities?
Old Apr 12, 2004 | 03:07 PM
Boomer's Avatar
Boomer
I was running 33psi cold before my Konis were installed. I'm running 35 cold now as recommended by the manufacturer.
Old Apr 12, 2004 | 05:52 PM
peterhong's Avatar
peterhong
33-35 Cold -- 37-38 Warm. 45 seems way too high for me since they will only expand as you run it during the day. And since you said 51 psi is the max, I assume after that the tire will blow right?? Take some air out immediately!!!!
Old Apr 13, 2004 | 01:05 PM
350Chas's Avatar
350Chas
I'm "running" 45psi, which is what it is when im driving.
OK i will take some out but the ride sure is nice!
If i put in 33-35 when cold, just a little more chill will bring them down to 32 and when i start her up i will get EEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE, low tire.
Damn screech!
Dsowe
Feb 17, 2021 10:38 AM
