Iforged owners: R U using OEM lugs?
Mounting mine tonight and it just occured that I might not be able to use the OEM lugs. I hope I'm wrong.
Thanks in advance
Josh
Thanks in advance
Josh
you are wrong..but you want to get hub centric rings
you need size 72.62,66.06
if you try and mount thewheels without them you will notice that its kinda hard to get the wheel centered on the cars hub because the wheel bore doesnt match the vehicle hub....you can certainly try..and i was driving without them for 4 months...but id rather be safe and it also prevents any "wobbling" that might have been happening due to improper mounting
got mine from prestigewheel.com
place the order on the phone its quicker
My Iforged came with the Hubcentric rings in a baggie stapled to one box...... Thanks though for the info.
I'm hoping my lugs will sit flush or recessed. The only picture I've seen where the lug tops were exposed was a set of Iforged using the old RS (2 piece) style wheels faces. If you look at Iforged website, the wheels faces differ b/w the RS series and FS series designs. It is my understanding that when you get them now......you only get the choice of the wheel faces in the FS series, but you can still specify it as a 2 piece construction. If that makes sense.
all said and done I want my lugs Flush....looks much cleaner. I guess if they aren't I can always look at replacing them.
