245/35s on 19 inch rims - too little sidewall?
Old Apr 27, 2004 | 11:56 AM
Strife350z's Avatar
Strife350z
Default 245/35s on 19 inch rims - too little sidewall?
For those of you running 245/35/19s on your 19 inch fronts... do you find that there isn't enough sidewall?
I did a search and generally speaking, most people are saying that the ride quality is the same, or only slightly worse, than stock
but having just ordered the Axis Hiros (a CAST rim), I'm concerned that a 245/35/19 isn't enough rubber to protect it from the roads here in Toronto.. if I had a forged rim, I wouldn't be so worried, but a cast rim has me concerned
Any thoughts?
Old Apr 27, 2004 | 02:58 PM
Agop's Avatar
Agop
Default Re: 245/35s on 19 inch rims - too little sidewall?
relax you got nothing to worry about-i felt the same way like you about 245/35r19 size tires .but thanks To gabriel, over at www.wheelstudio.com
he made a appointment for me over at axis wheels which is located in Santa Fe Springs,Ca.To allow me to test drive there nismo z which was fitted with this tire size and i thought it felt very acceptable.i never thought i would have had the chance to test fit this package but gabriel made this possible.he tells me to tell everyone at this forum thanks for all of our support.we will not be forgotten...
Attached Thumbnails 245/35s on 19 inch rims - too little sidewall?-640.jpg
Old Apr 27, 2004 | 03:28 PM
___DJK___'s Avatar
___DJK___
You really need to take into consideration the roads you will be doing most of your driving on. If they absolutely suck, I probably would have gone with an 18s. Since you already purchased your 19s, you may as well make them look proper and get the 35 series tires. If you feel you want a little more cushion, get a 255/35 up front if your rim will accomodate it. Its not much larger than a 245, but it will help.
Good luck!
Old Apr 28, 2004 | 05:17 AM
Dubby's Avatar
Dubby
you have nothing to worry about...I rock that size and around my way there is always some kind of construction going on, I haven't had any problems...just wrap some T1-s around them
Old Apr 28, 2004 | 07:45 AM
Strife350z's Avatar
Strife350z
so there's no concern of my cast rim getting bent from the small rubber? I understand that ride quality is fine, but my biggest concern is damage to my rims... i was thinking of running a 245/40/19 actually since 255/35/19 only adds 2-3 mm's of sidewall, where the 245/40/19 adds about 10 (granted this will cause my ride height to go up, but it's worth it if it prevents damage)
dubby - what kind of rims are you running?
Old Apr 28, 2004 | 08:18 AM
bwzabodyn's Avatar
bwzabodyn
If you run 245/40 front and 275/35 rear, you are basically doing the same thing all these people are doing who are running 245/35 front and 275/30 rear - except you are increasing sidewall instead of decreasing it - that's what I'm planning on running... and you will not have any VDC issues whatsoever...
Old Apr 28, 2004 | 05:45 PM
KarmaMag's Avatar
KarmaMag
If you want to run 245/40 in front, then I recommend 285/35 in the rear.
Put couple more pounds of air in your tires. It might help you from bending the wheels.
Old Apr 28, 2004 | 07:41 PM
rodH's Avatar
rodH
No worry? Heck yes, I worry about even my forged wheels, but maybe that is what will keep me from bending them. Careless people are the ones who end up bending wheels, just be careful
Old Apr 28, 2004 | 07:49 PM
Strife350z's Avatar
Strife350z
wait i'm confused... won't running more air in my tires result in a firmer tire and make my wheels even more prone to damage?
I always thought running less air would make the tire softer and therefore protect the wheel better
Old Apr 28, 2004 | 09:28 PM
rodH's Avatar
rodH
more air=more protection
Old Apr 29, 2004 | 04:57 AM
Dubby's Avatar
Dubby
sorry it took so long to get back to you...but I'm rocking Advans on my ride, and I don't have any problems...you r just going to have to pay close attention to pot hole in the road...if you hit a deep enough pot hole you will damage your rim but just riding on bumpy roads won't be a problem
Old Apr 29, 2004 | 05:01 AM
Dubby's Avatar
Dubby
just run 245/35/19 and 275/35/19 and you will be find....I wouldn't do 285 in the rear unless you have deep dish rims like a 19*10.5
Old Apr 29, 2004 | 09:33 AM
LATEZ's Avatar
LATEZ
HAVE 30 SERIES ON MY RIDE
SO FAR SO GOOD JUS AVOID POT HOLES
Attached Thumbnails 245/35s on 19 inch rims - too little sidewall?-2-2.jpg
Old Apr 29, 2004 | 10:21 AM
Strife350z's Avatar
Strife350z
looks great...
i think it obvious that I need to avoid potholes... but what if i can't avoid them?? today on the way to work I drove over a patch of bad pavement, it wasn't there last week when I drove that route... I probably went through 10 potholes, about 2 inches deep and 4 inches across... i was driving on my winters still (215-60-16) and I had no problems... ride was comfortable too for that matter haha... driving on those balloons
but would a 245/35/19 survive something like that?? potholes I can't foresee?
Old Apr 29, 2004 | 12:01 PM
LATEZ's Avatar
LATEZ
dont think you can worry so much about that !!! used to get dent all the time with my 17" jus depends on luck I guess ..if you hit a deep enough pot hole going at a certain speed dont think it would matter how big ur tires are ? if your in Cali dont drive after a rain storm
Old Apr 29, 2004 | 02:15 PM
Strife350z's Avatar
Strife350z
sigh... i guess i'll just bite the bullet and get 245/40/19s...
my Z's gonna look like a truck lol
Old Apr 30, 2004 | 04:54 AM
Dubby's Avatar
Dubby
just get the 35s and keep your eyes in front of the car stop looking at the babes rolling by and stop talking on the celly...keep your eyes on the pot holes coming up and go around them
Rev_Night
Nov 7, 2020 06:00 PM
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
