Wheel expert needed: Will these fit the 350z
Will:
275/30/19 (front)
285/30/20 (rear)
5.??? (offset)- The guy wasn’t sure
5 x 4.75 (bolt pattern)
fit for the 350z? The rims are coming from a 2002 Corvette. Any help would be appreciated.
Thanks.
275/30/19 (front)
285/30/20 (rear)
Thanks.
Thanks Robertchen for the quick reply.
The guy said he could attach “wheel adapters” to make it fit. Has anyone here ever used them....is it even wise to consider this route? If I do go w/ the wheel adapters, will everything else be ok.
not sure how they work, or how theyd work without a huge spacer.
with that said, the fronts might require fender rolling depending what the offset is. the rears might too with the same reason.
It won't work even with the adapter.
Corvette uses offset somewhere around +55 and the Z uses +22 to +35 depends on how wide the wheels are. You'll need at least 20mm spacer + a very long wheel studs.
If you need to correct both the bolt pattern and the offset, then the wheels shouldn't be on the Z.
