Bumpsteer?!
Old Apr 30, 2004 | 11:35 AM
Anishd's Avatar
Anishd
Default Bumpsteer?!
I've noticed that I've been feeling a lot more bumpsteer lately when going over bumps. When I hit a bump in the road, the steering wheel will jerk around a little bit. I have the Nismo S-Tune suspension installed, along with some Eibach sways. I have the sways set at the loosest setting in the front, and the middle setting in the rear. I didn't notice the bumpsteer when these were first installed. Can anyone shed some light on what could be causing it, or if there is anything I can do about it.
Also, here are my alignment specs:
Front Toe In: 1/32
Rear Toe In: 1/8
Rear Camber: -2 degrees
Thanks.
Old May 2, 2004 | 10:28 PM
Anishd's Avatar
Anishd
Bump for my bumpsteer question.
Old May 3, 2004 | 06:48 AM
D_Nyholm's Avatar
D_Nyholm
I have the same problem. I think it was always there, but I have really started noticing it after I installed my Hotchkis sway bars. Though I wouldn't think they would have anything to do with it though, maybe it is all in my head.
Old May 3, 2004 | 10:46 AM
luke350z's Avatar
luke350z
I have the stock suspension, and I have been feeling it lately, too.
Old May 8, 2004 | 06:28 PM
silver&black03's Avatar
silver&black03
ditto on stock and feeling it
Old May 9, 2004 | 12:26 AM
D'oh's Avatar
D'oh
How are your tires doing?
I noticed that when my front tires started getting down to slicks, the car was much more skittish over rough areas. It would be more likely to want to skuttle around a bit. It could be something like that.
Also, as the shocks wear, they might allow the tire to lift off the road a bit, which would unsettle the vehicle.
Finally, what about alignment? If your car is always pulling in one direction, then you will be applying a light oppsite force to compensate. When going over bumps, the car will usually do a little side to side dance because of this (happens to me on cambered roads).
Anyhow, those are the things that come readily to mind.
Good luck!
-D'oh!
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
J 0 K 3 R
Aug 11, 2011 01:18 PM
Apr 5, 2011 11:51 AM
