Correct Tire sizing when changing wheels...
Old Oct 8, 2004 | 11:31 PM
  #41
jreiter's Avatar
jreiter
Originally posted by tomzzy
I just ordered 265/35/18 (competition) 4 tires. Can I put these on the stock touring rims (18x8.5) or are they too big & should get wider rims? 265mm wide tires are about 10.4 inches wide. I will only be using for autoX & occasional track days.
I think the stock Touring rims are only 8" wide. Only the rear Track model rims are 8.5". (As far as I know.) I would guess a 265mm tire would be way too wide for an 8" or even 8.5" rim. Be sure to check the tire specs on the tire manufacturer's website. They'll have the acceptable range of rim widths listed in those specs.
Old Oct 21, 2004 | 12:10 AM
  #42
MarquisDeSam's Avatar
MarquisDeSam
I just bought a set of Volk SF Challenges 18 x 9 front and 18 x 10 in the rear. What would be the optimal tire sizes for me? Any help would be greatly appreciated, and look for pictures of my setup soon!
Old Oct 21, 2004 | 02:09 AM
  #43
jreiter's Avatar
jreiter
On a 9" wide rim, a 255 tire is probably optimal. On a 10" wide rim, a 285 is probably optimal. Just look at the tire specs for the tire models you're interested in. The manufacturers list their recommended rim widths for each tire size they make.
Old Oct 21, 2004 | 07:29 PM
  #44
MarquisDeSam
Thanks for the help jreiter. The recommended size that many different shops gave me (mackin, discounttire, yokohama, toyo, falken) is 245/40/18 front and 275/35/18 rear. This goes against what the forum guys are recommending, so I don't know who to believe. This setup will equate in a 2mm taller front than the rear, but everyone says it is optimal. Any suggestions?
Old Oct 22, 2004 | 01:50 PM
  #45
ez350e's Avatar
ez350e
Does anyone know the stock 17 rim offset that are on the enthusiast model? I want to get 18s but I am absolutely clueless on this topic and need some advice from you guys. There's a whole bunch of places that advertise 18 tire and rim packages but there's numerous variations, most of them come with 215s or 225s tire all around but i know that is not wide enough. I know the stock wheels and tires on the Z is 225/50/17 (17x7) in the front, 235/50/17 (17x8) in the rear. But then, the offset comes in to play where i have no idea how to calculate, so i figure if i know the stock offset i'll just have find a match. Bolt pattern is 5x114.3 if i am correct. For sure i'll be gettin 18s. I figure adding an inch in width for both the front and rear should do. If i want to get 18x8 in the front and 18x9 in the rear, what size of tires would fit? It seems like the consensus is 245/40/18 for the front, and 265/40/18 for the rear. Would those fit? Thanks in advance for the input.
Old Oct 22, 2004 | 05:50 PM
  #46
jreiter's Avatar
jreiter
Yeah, don't do that. Are these recommendations coming from a goofy automated system, or actual people? If you are going with those widths, then you want 245/40/18 and 275/40/18. A 245/40/18 is actually a bit *shorter* in diameter than the stock 225/45/18, while a 255/40 is the same diameter as a 225/45. I'd do the latter option if possible. (255/40/18 tires can be tough to find.)
Old Oct 22, 2004 | 06:02 PM
  #47
jreiter's Avatar
jreiter
If you search around you'll see that the most popular tire sizes are 245/40/18 front and 275/40/18 rear. The Nismo rims (which I feel are the perfect widths and offsets) are 18x8.5 (25ET) front and 18x9.5 (30ET) rear. Don't know what the stock 17" rims' offsets are. There are many variations on this, but those are what I personally feel look the best, and are recommended by Nismo/Nissan.
Some Volks rims, for example, often come in 8.5 (22ET) front and 9.5 (22ET) rear. In my opinion those offsets push the rims out beyond the fender too much and look sort of weird. Personal choice, I suppose.
Remember, the smaller the offset the further out towards the fender the rim sits. The bigger the offset, the further into the wheel well the rim sits. So something tiny like a 0 offset would result in rims that sat *way* out past the fender and would look stupid.
Old Oct 27, 2004 | 11:23 PM
  #48
ZurfRDR's Avatar
ZurfRDR
I only hear about people staggering!? What are thoughts about doing same front to rear. SCC did a test and pulled 1g w/ 18x9.5(or x9, I forget) all around, as well as w/ a few other slight mods. Aside from Warranty issues and VDC, which I don't have on my Enthusiast, is there a problem w/ this?
Old Oct 28, 2004 | 12:33 AM
  #49
jreiter's Avatar
jreiter
You can read about it on SCC's website. They've got that whole article. They used a 9" wide rim up front and a 9.5" rim in back, but the same 275/40/18 tires all the way around. So effectively they are indeed running the same diameter all the way around. This shouldn't cause a problem except that the traction control system might kick in more easily since it expects a bit of a stagger. However, turning off traction control will eliminate that problem.
I'm seriously considering doing the 9.5" wide Nismo rims all the way around with 275 tires on all 4 corners. I already have the normal Nismo set, so I'd only need to get another pair of the 9.5" rims. I just keep being too lazy to get out there and try out the fitment. (Jack up the car and mount the rear rim on the front to see how it fits and check clearance on the suspension uprights.)
Old Oct 28, 2004 | 07:45 PM
  #50
swsegal's Avatar
swsegal
On a 10.5 inch rim 295/35/19 will rub like hell- I already had this problem. One solution is to roll the fenders, which at worst could result in paint cracking and you would have to repaint the quarter panel. Easiest solution is to just stick with the 275/35/19
Old Oct 31, 2004 | 07:19 PM
  #51
Lawn Dart's Avatar
Lawn Dart
[Front]
17x7.5 +30 (Base/Enth)
18x8 +30 (Perf/Tour/Track)
[Rear]
17x8 +33 (Base/Enth)
18x8 +30 (Perf/Tour)
18x8.5 +33 (Track)
Old Nov 2, 2004 | 04:25 PM
  #52
Mr_Q's Avatar
Mr_Q
Originally posted by Audito350Z
I run 245/40-18 front and 255/40-18 rear on my Track model wheels... I don't remember the actual numbers, but that set up is close to OEM dimensions
PeteH
I wonder if that would trip up the VDC? You kept the stagger pretty much OEM so I'd think it wouldn't.
Old Nov 2, 2004 | 04:30 PM
  #53
Mr_Q's Avatar
Mr_Q
Originally posted by jreiter
It's the tire size that affects things, not the rim size. (Of course, rim size limits your tire selection, so I guess it does come into play a bit.)
A 255/40/18 and 275/40/18 combo is the closest to stock diameters. (Almost perfect.) That's going to be my next size combo when I replace my tires.
Would your above suggestion fit nicely on the stock Touring rims?
Old Nov 2, 2004 | 08:51 PM
  #54
jreiter's Avatar
jreiter
I believe the Touring rims are only 8" wide, so I don't think a 275 width tire would fit. Even a 245 might be near the max. Like I always say to folks, please check the tire manufacturers' websites for the range of rim sizes that will fit with a given tire.
There are people who certainly go beyond the recommended sizes and don't seem to have problems, but I can't comment on that. I personally wouldn't want to go outside the manufacturer's recommendations.
Old Nov 2, 2004 | 08:58 PM
  #55
jreiter's Avatar
jreiter
FYI:
The stock 245/45/18 tire has an outer diameter of 26.68". A 255/40/18 has an outer diameter of 26.03". That's a significant difference in diameter.
The stock 225/45/18 tire has an outer diameter of 25.97", while a 245/40/18 has an outer diameter of 25.7". Not a huge difference, but notable.
As you can see, a 245/40/18-255/40/18 combo doesn't even come close to the stock stagger. The 245 is shorter than stock, and the 255 is *much* shorter than stock. However, if you just disable VDC then it won't complain at all.
If you want to remain as close to the stock diameters as possible, then a 255/40/18-275/40/18 combo is the closest in diameter to the stock sizes. Almost perfect. This is what I'll be going with next.
Old Nov 2, 2004 | 09:50 PM
  #56
Mr_Q's Avatar
Mr_Q
Which is what I wanted to do...but you are say'in my stock wheels might not be up for it? Tourings are F: 18x8s and R: 18x8.5s right?
Old Nov 2, 2004 | 11:56 PM
  #57
Florida350zrt's Avatar
Florida350zrt
Default 18"-8"
The stock touring wheels are 18"- 8" all around.
Old Nov 3, 2004 | 11:02 AM
  #58
jatt350z's Avatar
jatt350z
Default Re: Correct Tire sizing when changing wheels...
I got 245/35/19 and 275/30/19
I do have my tcs come on once in a while and it is annoying. i am gonna get the 35 next set, but cant do anything now. id also recommend going with the 35 becuase of my expericnce
Originally posted by DiscountTireDirect
Oh boy....Ive been over this again and again. Seems as if these shops that 'know everything' really dont know much at all. Most common is found in 19" upgrades when some random shop suggests 245-35-19 with a 275-30-19 rear. THE REAR TIRE IN THIS SITUATION IS SHORTER!
1st issue:
Nissan wants between .5 to .75" stagger front to rear, rear being taller of course.
2nd issue:
you WILL anger vdc, trac, abs
3rd issue:
The dealer doesnt need much reason to try and void your warranty. Ignoring their stagger rule is one thing, doing a rear tire thats shorter is even worse.
4th issue:
It looks wrong. a 275-30-19 rear is 1.2" shorter in overall diameter than your stock rear tire. Why would you do this?
For most 19" 350 applications you should have a 245-35-19 & 275-35-19 or 285-35-19 rear tire. Anyone who tells you otherwise is mistaken. the 35 series rear may be a bit harder for them to find, or maybe they were told the wrong information. Either way, it is the incorrect setup...and a lot of you on the board have had this mistake happen to you.
Maybe it will cause and issue. Maybe it wont. I sure wouldnt want to find out while going 60 on the highway in the rain in CA when a wrec happens around you and your abs decides to freak out. Just my .02.
Take a look at the calculations below.
this one is stock size rear vs a 275-30-19 rear
this is the 245-35 & 275-30-19 incorrect combo
and here is the correct 245-35 & 275-35 combo
Most commonly 18" upgrades should be
245-40-18 with a 275-40-18 rear
and in 19" it should be
245-35-19 with 275 or 285-35-19 rear.
TIRE SIZE CALCULATOR
Old Nov 3, 2004 | 11:35 AM
  #59
Mr_Q's Avatar
Mr_Q
According to that calculator if I took my stock tires on my Touring and swapped them out for
F: 255-18-40s R: 275-18-40s
my front to rear overall diameter difference would be .29...compared to the stock .28.
That's gnarly and should keep the VDC more than happy.
Old Nov 4, 2004 | 01:54 AM
  #60
jreiter's Avatar
jreiter
Correct, that's what I've been saying. When it comes time to replace my tires, I'll be going with that.
