using rear wheels up front....
Old May 8, 2004 | 07:08 AM
HarvesterUT's Avatar
HarvesterUT
Default using rear wheels up front....
this might sound silly, but is it possible to use the rear wheel size up front as well as the back?
lets say i wanted to get the Nismo 19" lmgt4....but i wanted the same size all around. would it be possible to buy 2 sets of the rear only...giving me 19x9.5 all around and letting me use up to 275 all around (or even wider in the back....up to 285?)
is there enough space in the front to do this safely??
Harv
Old May 8, 2004 | 07:21 PM
HarvesterUT
anyone?
Old May 8, 2004 | 07:28 PM
2003z's Avatar
2003z
what is the offset of the nismo's. IT should be.
Old May 9, 2004 | 02:51 AM
HarvesterUT
i know the LMGT4 18" rears have a +30mm offset......would the 19's have the same offset?
Old May 9, 2004 | 03:13 AM
FritzMan's Avatar
FritzMan
Default Re: using rear wheels up front....
I have often considered doing the same thing. Based on my research, I don't see why not. SCC (Sport Compact Car) mag claims a 9.5" wide tire with 30mm offset and 275/40/18 can fit up front, although there was some very light rubbing at full lock.
Harv
Old May 9, 2004 | 04:09 AM
HarvesterUT
Default Re: Re: using rear wheels up front....
light rubbing? i dont like the sound of that. i really like the lmgt4 19", but i wanted a wider tire than 245 (or 255 i assume would fit on 8.5").
oh well i'll keep looking into it
Harv
Old May 9, 2004 | 05:55 AM
zillinois's Avatar
zillinois
I have a 9" (offset 25) with a 265/35 up front. I'm even lowered an 1" and have plenty of room. No rubbing. You should be able to get a 275/35 in there.
Obadabot
Jun 18, 2023 11:31 PM
